Question about Sanyo DS24205 24" TV
TV got sound but only shows a complete white screen and the message no signal connection
From one day to another the TV doesnt show image, you can hear sound but no the image, a message appears that says that cand find a signal and check the connection, I use another TV set and the connection is working, what is wrong with this TV Sanyo DS24205? Help Please! Thanks
    Genius:
  • 1,074 Answers
Call a tech your tv needs to be repaired tv is having a problem in the video circuit ther is a cip that controls that circiut checks should also be made in the related circuit.video IF circuit.good luck
Posted on Apr 11, 2007
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Why does screen show 'no signal' message?
generally that sign means that there is no signal from the transmitter of the tv company
if changing channels shows as programs then it is at the tv station
if you are moving the aux input selection and there is no wii or dvd,cd pc connected it will show as no signal
basically it is no input signal into the tv set
Sep 16, 2015 | Seiki Televison & Video
Why do I have a frozen image screen on my old Admiral color tv. Do not have cable and the converter box works on my other tvs.
You may have paused a still image on the TV. Information channels and video games left on pause will burn images into the screen. You may opt to find a signal generator that can produce a white screen Sometimes this will erase the image/ghost you see. See a TV Repairman, and show him this info! Thanks for asking, Matt of Martins TV.
May 25, 2014 | Televison & Video
The screen shows a green/ orange screen, even when we play a DVD... How can we make that go away?
How is the player connected to the TV? It could be S-Video, HDMI, RCA, or Component Video cables. My guess is that you're using component video cables. There will be three wires that carry the video signal to the TV, and each wire carries one color. There will be a blue, yellow, and green cables. If one of these cables is not seated properly, it can cause only one or two of the three color signals to make it to the TV, causing the image to be discolored. You should check the connections of the cables. You'll also see the sound cables, probably red and white. Do not get the red video and the red sound cable mixed up!
Jan 16, 2011 | Philips DVP3982 DVD Player
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
No Signals
You may have to access the initial setup menu to force the set to look at the cable input. Although that is typically the default today, it may be looking for signals from an antenna. Broadcast and cable use different frequency ranges so the set has to be able to see the range you are trying to watch.
Dec 06, 2008 | Philips 20PT6441 20" TV
Laptop connection to tv
dear sir.
u have to ser yr tv resultion and do as same as tv in to yr laptop after that it's a tool given by drviers chek that this avalable in display propeties>setting>advance>adapter.. here u have all kind of setting avalable...:)
Thanks
please vote
jo_chinmay
Nov 17, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
Sanyo DS24205 24" TV Logo
87 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
