Question about Tomtom GO 510 GPS Receiver
TomTom GO510 will not switch on
Charged for over 2 hours green light showing unit will not switch on even when connected to computor and pushed the reset button
  • 495 Answers
I think, your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
Posted on Dec 10, 2008
  • Manoj Rout
    Manoj Rout Dec 10, 2008
    what you can do is hit the reset buttton twice or thrice.
    Master:
  • 351 Answers
Dear David,
please try to reset the unit, there is a small hole near the docking connector.
regards
  • 734 Answers
May be there is a problem in battery.
thanks
How do I start my tomtom 2405. It has been sitting for 1 year. Charged overnight. The start button is green
Have you tried to RESET it ? .... either, hold down the power ON/OFF button for a long while ... (e.g. 30 seconds or more) ... until the device starts up (then let go)..... or use a pin (paper clip) to push into the RESET hole at the bottom of the device.
May 11, 2014 | Tomtom GO 2405 TM GPS Receiver
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
MY TOMTOM WILL NOT SWITCH ON EVEN THOUGH I HAVE CHARGED FOR OVER 12 HOURS. THE GREEN LIGHT SHOWS ITS CHARGING. WHAT COULD POSSIBLY BE WRONG?
Curious... how long have you held down the power button to turn it on? I've had to hold the power button on mine for 2 mins once to power it on.
Oct 15, 2009 | GPS
Tom tom just stopped working
my tomtom does it now and then. solution is to take it to the car plug the car charger in to it, then press the reset button wait about 3 or 4 secounds and should come back on you don't have to remove your card. plging in to the computor does nothing it needs power when you press the reset botton
Sep 07, 2009 | Tomtom GO 720 GPS Receiver
Our tomtom one 3rd edition stopped working it will not switch on or charge up even th ough green light comes on charger when plugged into car
try resetting it, but first put it on the charger for a few hours to make sure its charged. using a paper clip or something similar, depress and hold the reset button located on the bottom of the unit for 15 seconds, then hold the power button for up to 5 seconds till the unit starts.
if that fails, hook your tomtom to your computer and run tomtom home and see if that will update or repair it.
tomtom
let me know if you need further help.
bill
Aug 26, 2009 | GPS
No power in battery
the battery has collapsed and needs replacing immediately to prevent leakage damage Takew to service centre
Jul 04, 2009 | Tomtom GO GPS Receiver
I purchased tom tom go510 14months ago, but it will not charge in house or car charger, what shall i do, this cost me over 269.00, i am not very happy its only lasted just over 12 months
I would call tomtom and see if they can send you a new battery sounds like it might be bad,is the green light showing that's it charging?if so and the battery isn't holding a charge I would call them and say that it went bad about 2 months ago.Good luck
Jul 28, 2008 | Tomtom GO 510 GPS Receiver
Sat nav
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 20, 2008 | Tomtom GO 700 GPS Receiver
Switch on problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 09, 2007 | Tomtom One Europe v2 GPS Receiver
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
26 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
