Question about MTX Thunder 8302 Car Audio Amplifier
Delay When I first get in the truck and I turn the radio on it takes the subs about 10 to 20 mins., for them to sound. There is power going to the amp. The LED light is on. All wires are connected correctly. What could be the problem?
  • 62 Answers
10 to 20 minutes? that sounds like a internal problem in the amp. I have never heard of a amp taking that long to start up, there is definatly a problem in the pre amp stage of the amplifier.
Posted on Mar 26, 2007
Wont stay on. It'll load for 3 secs then turn off
The Calculator has a feature that takes it into standby after a certain delay of inactivity. Possible values of the delay are 1 min, 3 min, 5 min, 10 min, and 30 min.
In view of this, your 3 sec value seems too short. I suspect that the batteries are depleted.
In OS 2.x, press 5: Settings & status, then 3:Handheld Setup. Look for drop down box to the right of Power Standby, and select a longer delay.
Feb 04, 2011 | Texas Instruments TI-Nspire Graphic...
Delay in radio turning on and lights turning off
Sounds perfectly normal.. when you turn the engine over all power is diverted to the fuel , ignition and starter .. once the engine is running everything else powers back up... The interior light is designed to be that way , some have a adjustment as for how long you want them to stay on .
Jul 29, 2010 | 1999 Buick Regal
Popping and Humming noise from my audio system?
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Oct 05, 2009 | Pioneer DEH-P6400 CD Player
Subwoofers were said to be bad
overpowered definitely. when you bridge subs your almost doubling the power. if the subs were set for 2000 then the guy he took them too should have known better or at least turned the power down on the amp.
Mar 13, 2009 | Car Audio & Video
Gmc envoy remote key not working
Sounds like you need a new keyless entry box, but forst try resetting the computer, by taking the positive battery cable off for 10 mins.
If that does not work then seek geting the box for the keyless entry replaced.
Nov 23, 2008 | 2004 GMC Envoy
No sounds through sub and rear speakers
Your radio probably has a sub on and off function on it that was reset when it lost power. Go into your setup menu to turn it on.
Oct 21, 2008 | Car Audio & Video
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Sub is getting no sound
Sounds like you answered your own question when you said you were getting no sound from your deck to your sub.
Jan 23, 2007 | Koiiler XM-6666W Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier Logo
55 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
