I have 2 hp 3600 laser printer .and they both have the sme problem when i put the 4 cartridges the yellow doesn't print thanks
  • infoahmed Dec 10, 2008
    no these are all new cartridges?and the problem is happening with both printers cause i have 2 hp 3600 thaks
  • 60 Answers
There is one problem with your cartridges if you use the same
Posted on Dec 10, 2008
  • Service SCM
    Service SCM Dec 10, 2008
    try to made a head cleaning but before place the cartridges try to **** with your mouth to see if yellow color apear on the head of that cartridges
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 ( if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Amigo error 10.32.03 laser 3600 hp como solucionarlo
Your yellow toner cartridge is bad.
Get it replaced.
Feb 24, 2011 | HP LaserJet 3600n Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
My HP color Laser Jet 3000/3600/3800 is sqeaking
You need to clean the carriage ride path for the cartridge.
Aug 12, 2009 | Office Equipment & Supplies
Help when I print i get yellow and black lines across the page through out from top to bottom for an HP 3600n laser printer
First thing to do is exchanging the black and yellow cartridge. Mostely the problem is solved.
Jul 11, 2009 | HP LaserJet 3600 Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Jan 01, 2009 | HP Color LaserJet 2600n Printer
HP leaser jet 3600 doesnot print yellow
Clean the toner contacts in the printer
May 15, 2008 | HP LaserJet 3600n Printer
63 people viewed this question
