Question about Sharp AL-1000 Copier
PLEASE HELP ME
I HAVE THE SHARP AL-1000 AND THE SYMBOL THAT LOOKS LIKE A ROLL OF FAX PAPER IS FLASHING,THIS SYMBOL IS LOCATED ON THE RIGHT OF THAT TRIANGLE THAT LOOKS LIKE A CHRISTMAS TREE,WHAT DO I HAVE TO DO TO STOP THE FLASHING FUNCTION AND MAKE IT PRINT,THANKS.
  • petertsougri Dec 17, 2008
    no can you please email me instructions,thanks so much for responding.
  • petertsougri Dec 18, 2008
    HEY ROGER YOU ARE A SUPER MAN,YOU SAVE ME BIG TIME PROBLEM,I AM WITH OUT A PHOTO COPIER 6 DAYS NOW AND THANKS TO YOU THAT GAVE ME THIS HELPFULL INFORMATION,THANK YOU SO MUCH,BEST WISHES TO YOU AND YOUR FAMILY.GEORGE FROM GREECE.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
You have to reset your drum counter in the maint mode. do you knoe how to get in the maint mode?
Posted on Dec 16, 2008
  • Roger Binsfeld Dec 17, 2008
    first you have to find these buttons.clear key which has just the plain red c on it then find the auto button it is the button you would push to change the darkness from auto to manual . it is near the middle of your copier by the picture of your copier. now you have to push these buttons in this order and fairly fast
    clear, auto, clear, auto. the machine should go dead [blank]. if it does not you must push the buttons faster one right after the other. once the machine goes dead then using your arrow keys make the window say 24. press your start or print button. it will start flashing zero's at you. press the right arrow key until the window shows you 06, press your start/print button it should start flashing zero's at you if not change the 06 to 07 and press the start/print button it should now be flashing zeros. if this happens then press your clear button 4 times this will take out of the maint mode and your drum light should be gone. if you have trouble with this call me at 1-320-251-0092 i will walk you thru it .
    roger
I have a SHARP UX178 fax machine that displays all the time the message out of paper but the roll paper is corectly installed. Ther is a sensor or a contact that has to be checked? Thank you
yes there is a sensor or a switch
when you slide the paper under the roll in the middle you should see the switch ot sensor some models have the sensor maybe on the right or left kyou need to look for the sensor or switch
hope it will help
Oct 11, 2010 | Sharp UX 108 Roll paper Thermal Fax
Sharp AL-1631 copier. Red flashing triangle no owners manual. Dosn't work. Help
Flashing triangle of dots? for your reference, this is, and always has been, the universal symbol for add toner.
...and here's your manual:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Feb 25, 2009 | Sharp AL 1631 Copier
Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
Nov 09, 2008 | Sharp UX 108 Roll paper Thermal Fax
H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
Oct 20, 2008 | Sharp AL-1000 Laser Printer
How to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
SHARP AL-841 Paper Misfeed Error? The little paper mis-feed symbol is flashing - though there does not seem to be a jam ANYWHERE. The copier will not re-set.  Can someone help? Thanks, Ron...
open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
remove tray and look where paper feeds out.
Nov 19, 2007 | Sharp AL 1631 Copier
Sharp AL-1000 Copier Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
