Question about Kenmore 75022 / 75024 / 75029 Gas Kitchen Range
Control panel & Oven doesn't work
I was preheating the oven today and all of the sudden the control panel started turning the whole oven on and off. It did this for over an hour. It would click on and off and then stay on for a second and then off for a minute then click back and forth. When it was off the range still worked but not the control panel or the oven. When it would click back on the range and oven would be locked like the power had gone out. Thank you, April
    Scholar:
  • 76 Answers
APril b Most likely the problem with your range is shorted pads on the key pad. It is not repairable and the key pad has to be replaced. If you would like to do it yourself, I need the complete model number starting with a three digits prefix(the name plate is located on the frame behind the storage drawer) and the color of your range. Then I'll be able to help you to find the best deal on the part and provide you with the step by step instructions to replace it. Gendos...post back
Posted on Mar 02, 2007
Sf367lxss 2 turns off during preheat
F2 E0 is certainly a the error for a stuck key on the pad. Did you buy a new? If so you need to return it and have it replaced. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 09, 2013 | Whirlpool GR773LXSS - Stainless Steel...
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven does not light
even if the ingitor glows, and the oven wont lite, the odds are that the ingitor is bad. it must draw 3.2 amps to open the gas valve. the only way to test the ignitor is with an amp probe. replacing the ingnitor is about 90% a sure thing.
Dec 08, 2006 | Hotpoint RGB745 Gas Kitchen Range
Kenmore 75022 / 75024 / 75029 Gas Kitchen Range Logo
169 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
