Question about Intel Motherboard
P4 problem dear sir , i have p4 motherboard, whene i put the viga card in agp slot it turns off ,the viga card is good , what is the problem?
  • bassel_ahmed Dec 10, 2008
    i said the viga card is good , itried it in another pc and works
  • 80 Answers
Have you tested another vga card ?
Posted on Dec 10, 2008
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
Can I instal an agp video card to the motherboard p4bgl-vm?
Please check inside the computer case if the AGP slot is there, according to the user manual there is no AGP slot and so a AGP card has no connector on the mainboard to be connected to - No it can not be installed to this mainboard.
You can only use PCI Video cards if there is no AGP slot.
Jan 23, 2011 | ASUS P4BGL-VM Motherboard
Biostar u8668 grand does not power up when agp
Good Day sir, try to check the CMOS/BIOS setup, and go look for Initial Display First, there are several options, Onboard / AGP / PCI. OR, after you remove your AGP, clear the CMOS/BIOS setup. find the jumper wire near the battery this sets your motherboard to factory setup and uses the onboard VGA. test the pc without the AGP.
Oct 18, 2009 | Biostar U8668 Motherboard
Agp sockt missing on pc motherboard
Easy answer. NO. There is more missing then just the Slot.
Aug 11, 2009 | Koss P4 Consumer Headphones
Desktop upgrade
Asus is a Solid MotherBoard manufacturer of mother boards. If you are looking for an add-on graphics card (I'm assuming you want to do some gaming), You would want to upgrade the memory for that motherboard to at least 1GIG which can be found here.
Graphics cards wise, I wouldn't advise anything higher then a $100 card... As that motherboard only supports 4x AGP (The type of connection your video card would use) and to get more for what you pay for, you really need a motherboard with an 8x AGP slot to get 100% of what you pay for. A Radeon 9950 at around $92 is the most you would want to put into a system that currently has a p4 2.66 ghz.
Mar 13, 2009 | ASUS Computers & Internet
HOW TO GRAPHIC CARD
Hi im josh in cebu phils. may i helped you? It simple problem friend. since your motherboard is p4 and it has an avp slot not pci e.You buy AGP graphic card having a higher memory 256 or 512 mb and 128 or 256 bit. so that you will get the the best performance on that p4 board. i suggest to get higher ram and bigger hard disk space and a sound card for maximum performance.Good luck..
Feb 16, 2009 | Asrock P4I45G Motherboard
Graphics card issue - GA-0ST800 Motherboard
Your motherboard have an AGP 4X port, you can easy upgrade whit that card since it is an APG-card. Not sure tough that your motherboard can handle all that DDR3 power witch come with the card but im sure u will notice a big improvment.
I think that a cheaper card with 512 Mb DDR2 will give u the same results.
Good luck
Nov 21, 2008 | Gigabyte GA-8ST800 Motherboard
Upgrading VIDEO CARD
If your motherboard's graphics slot is AGP and your graphics card is AGP then it should be fine if your motherboard is PCI-E and graphics is PCI-E it also is fine make sure your motherboard and graphics are compatible.
May 29, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Faulty agp socket
You can use a PCI slot video card or the internal video if the motherboard has it. there are also ISA video cards (really old and cheap 1-3 dollars)available incase your board has those slots.
If the socket is faulty you could replace it, first of all make sure the pins on the agp slot are not touching or it might cause issues with the computer.
Apr 12, 2008 | Koss P4 Consumer Headphones
ABMZN-LA motherboard
sounds like 8x agp. go to new egg.com. good deals on vid cards there. unfortunately for you the agp doesent get into the higher end video cards. nor does the standard pci. the transfer rates just aren't fast enough. but unless you are doing serious gaming either pci or agp will give you about the same frame rates.
Feb 24, 2008 | Compaq Evo D310M 845G P4 Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
