Question about Zanussi ZWD1470W Front Load Washer / Dryer
Leak after cleaning out filter
I have a Zanussi ZWD1471 and after I cleaining the filter the machine is leaking!
It may be theat the hose is not in its place, how easy is it to check and replace
  • sharondoron Dec 10, 2008
    I have screwed the filter cap back on tightly after cleaning the filter.
    I think that the little hose next to the filter has come out of place!!!
  • Zanussi Master
  • 3,463 Answers
Make sure that you have screwed the filter back in tight, and also check that there is no dirt or anything else round the filter seal to stop it sealing proerply.
Posted on Dec 10, 2008
    New Friend:
I just had the same problem last week after cleaning out filter. I replaced the filter but the problem continues.
I would like to know if it is easy to solve this problem or I am going to have the same problem again. It maybe a better idea to buy a new one.
Thanks
Mary
Posted on Sep 08, 2013
My zanussi us leaking water as soon as it starts to fill. I've cleaned the pump and detergent door but no help. It's leaking from underneath somewhere
It sounds like there may be a split in the fill hose! Go to the Zanussi web sit and you should be able to buy one for a few £££. Take the top and back off your machine and you should see the hose if you follow the pipe where the water connects.
Dec 16, 2014 | Zanussi Washing Machines
My washine machine is displaying the code e20 can you advise the model is ZWF1640W
The manual says this is due to a blockage.
Check your hoses, make sure they have not been squashed / blocked. If they are OK, check the filter at the front of the machine, it's under the flap. Careful, when you open the cap a lot of water will leak out, so be prepared with a tray or something.
Losen the cap, let some water drain then empty the tray, keep going then eventually pull out the filter. Clean it out completely and refit. Test the machine, it should work ok.
Mar 13, 2011 | Zanussi ZWF1640 Front Load Washer
It is leaking water from the bottom as it washes
Plug off the mains. Open up the washer top & behind. There should be a loose or torn rubber pipe. Examine all hoses (pipes), including door seal. Three pipes go from the inlet to soap holder, below the drum you will find a big hose to the filter and pump. If you cannot find anything turn the machine on (keep kids away, locked out). Run the machine without clothes or soap to observe where the leak comes from. You can either tighten the hose, with mains off or replace the hoses. Try sites below for spares with make & model number, depends where u are.
marcone.com
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Feb 12, 2010 | Zanussi FJS1225W Front Load Washer
My ZWD1471 started leaking during the drying cycle recently. It doesn't leak during the wash cycle. The water seems to be coming from underneath the back of the machine, I think on the righthand side. Any...
open it and see where the leack come from it might be the drain pump and it easy to replace or it might be a hose that got burst...
see if you can open it from the back or the bottom front
Feb 07, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi front loader leaking
Most likely you have a pump shaft seal leaking you can buy a new pump at this site. You may remove the pump and clean with pool muratic acid, but it is very caustic you would have to put pump in the acid bath in a metal pan that you don't mind using it and it will eat all the organic buildup from the pump. However it may leak worse as the organic material may keep it from leaking too much. So I suggest you use the pump, if you use mueratic acid it is highly toxic so read directions on using it and were air mask and rubber gloves while using it then rinse off with clean water. You should put water hose in the drain pipe and tunrn on the water to test the drain pipe as well. this will make sure the drain pipe is fine. Look at the hoses near the clamps as this is where holes develop on the water pump hoses.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Zanussi+front+loader
Sep 05, 2009 | Washing Machines
Beko wmb1ow leaking cant see where from
Have a look at the hose that runs from the dispenser to the tub front.
They can leak when they rub against the shell.
Hope that helps
Nov 25, 2008 | Zanussi ZWF1430W Front Load Washer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
225 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
