Question about Dryers
I have a hotpoint ctd80 showing error f13, have cleaned all the filters, and cleared the water and still it doesnt clear error on the low heat setting
  • 3,463 Answers
F13 indicates the rear thermistor is open/short circuit, this is part of the heater circuit. it is akin to a thermostat, but there is more than one!!
Hotoint recommend you call an engineer..
I am assuming that this is a lcd tumble dryer.
Plz leave feedback.
Ta.
Posted on Dec 10, 2008
Ctd80 hotpoint dryer panel flashing dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two small screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Feb 27, 2014 | Hotpoint Dryers
Hotpoint ctd80 smells musty
Ensure filters are all clear and try using tumble dryer sheets to fragrance clothes which should get rid of musty smells.
Sep 11, 2013 | Dryers
Optima G2430 Miele dishwasher with F13 error
F13 Indicates that you have a water intake fault. The machine is not receiving the the proper amount of water quantity. You could turn off the water supply and disconnect the water inlet hose. There is a filter inside, to remove the filter you have to take out the seal and then you could use a pair of needle nose pliers to take out the filter basket. If the filter is clean you and your water supply is good, you have a problem with your flow meter not registering pulses when the water is taken in.
Feb 05, 2012 | Miele 24 in. Incognito G843SCVi Built-In...
I have error code f13, can you help, please..
This s is how i fixed the F-13 Fault on my Hotpoint WD 640 washer dyer. Simple to fix just see the pictures and explanation. Hope this clears things up
Boxie
1_7_2013_12_28_59_am.jpg1_7_2013_12_29_33_am.jpg1_7_2013_12_31_38_am.jpg1_7_2013_12_31_56_am.jpg
Aug 07, 2010 | Dyson Memory CRO1 Front Load Washer
Ctd80 hotpoint condenser dryer not heating up at all showing error message f 14 think its thermastat
Error code 14 indicates dryer element fault.
Checkelement-connections-and control module.
Please leave feedback.
Thanks.
Nov 15, 2009 | Hotpoint Dryers
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima CTD80
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Sep 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Sep 02, 2007 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
226 people viewed this question
Top Dryers Experts
