Question about Bosch WTE86300 Electric Dryer
Bosch wte8630 condensor dryer
How do you remove the cooling grille to clean it out
My bosch 8kg condensor dryer just switched off and now doesnt want to switch on again. everything is clean and there is just no power.
Check and make sure the exhaust air duct is clear of lint, it may have overheated due to poor exhaust airflow.
Oct 20, 2016 | Bosch Dryers
My 91 Chevy pickup overheats when the AC is running. It normally runs 150 degree, but when the AC runs, it climbs to 220-240. All fluids and belts are OK. Thermostat is OK
is there a grill insert if so remove
is condensor clean (front a/c rad) clean with garden hose pressure
are fins of condensor folded over (they can be comb back to shape)
is engine cooling fan working when engine hot rev engine and look at fan
to see if fan responds to engine rpm properly
if fans electric check to see if power is there when a/c is switch on
should go on immidiatley with a/c switch on
Jul 20, 2011 | 1991 Chevrolet K1500
How do I remove cooling grille on my WTE86300BY/02? I don't want to break it. I regularly clean air cooler with warm water, taking it out through the maintenance flap. But I can see that inside the...
I had the same problem on a WTE8630SGB. There are six plastic insert/clips and I removed the grille panel by lying the machine on its back to get to the underside. Each plastic clip has three fingers and the middle one rotates to release - you are is supposed to be able to press the middle fingers one's lever arm - but it invariably breaks off before rotating enough to release - so i used a very fine screwdriver to prise the middle finger away from its release. One still snapped as the plastic is so brittle. Prise or rotate the bottom three and the top three hinge away. In my my 4 yr old machine there a little fluff build up on the impeller centre and on the (rather strange) cowl lining but on balance don't think it was worth the trouble of removing the grille!
Have fun
Alano, Chelmsford UK
Mar 05, 2011 | Bosch WTE86300 Electric Dryer
The freezer will not stop runnig
Refgriderators loose some of there cooling capacity if the condensor coils are not kept clean .To clean the coils pull out the fridge, remove the front and back bottom grill and vacoom or blow all the lint off the grills.If blowing out ,it can get messy.I usually put the vacuum in the back,cover the rest of the opening with a towel and use air to blow from the front.Hope this helps if so please give us a 4 thumbs up. THANKS
Mar 03, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
I have a stackable unit. The condensation dryer is on top of the washer. There is a light leak coming from the dryer. What can be causing this?
a leak from a condensate dryer is probably coming form the condensor itself, have you taken out the condensor and cleaned it lately, if so check the resivor where the condensed water is supposed to be collecting, have you emptied that?? perhaps it wasnt put back in properly???
Nov 02, 2008 | Bosch Dryers
Bosch freezer
Condensor coil needs cleaning.
Aug 02, 2008 | Freezers
Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
May 22, 2008 | Dryers
Bosch WTE86300 Electric Dryer Logo
212 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
