Question about Dishwashers
Blanco Dishwasher bfdw 6505 - When I put the cycle on the dishwasher starts, but there doesn't seem to be any water entering the machine and the dishwasher soon stops.
  • j10nt Dec 22, 2008
    Same problem
  • pjb_ban Apr 04, 2009
    Me too.. same problem with the bfd9x!
SOURCE: Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Posted on Aug 19, 2008
SOURCE: I have a Blanco Dishwasher
Try unplugging it from the wall socket and leaving off for about 1 min then plug in and turn back on
Posted on Aug 14, 2009
garing
  • 998 Answers
SOURCE: no water entering the machine
be sure flood control float is in place ..under rack..check flood control switch under bottom of dishwasher...check inlet valve and timer
thumbs up
Posted on Aug 17, 2009
  • 512 Answers
SOURCE: Water Won't drain fro the dishwasher model Blanco bfdw650s
If you "Lower" the hose to the bucket and it "drains" you are just using gravity to remove the water. The pump may be helping a little but if you raise the hose up and the water stops coming out, it's a good indication that the pump is bad. Unless the place you are attaching the hose to is plugged up, you need a new pump or a new impellor. Since the motor is good, try to get a replacement impellor, that the thing that moves the water. One other thing, you did say how well it washes the dishes? If the impellor is bad, it probably doesn't.
Posted on Sep 08, 2009
heatman101
  • 43501 Answers
SOURCE: bfdw 650s blanco dishwasher leaks waterout the front
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
n
Posted on Sep 29, 2010
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
I have inherited a Blanco Bfdw 650s Dishwasher and there seems to be a manual dial as opposed to automatic ones which is what I'm used to...does this mean I have to stay home to help the machine perform...
No! Set the cycle you want first (A/B/C) THEN turn it on. It will just run through. I've just found my PDF instructions and trying to work out a way to upload them.
Nov 08, 2012 | Dishwashers
Blanco dishwasher error d06 faulty motor.
I have a Blanco BFD10X Dishwasher which had the same D06 error, being a Electrician i investigated the fault which Blanco report as motor over current. After testing the motor, i tested the motor Run capacitor and found it to be faulty, these capacitors are common to failure and will cause the pump to draw more current than usual.
A genuine replacement 2.5uf capacitor was quoted at $120.00, however i purchased a equivalent from RS online for $14.30 + delivery. RS P/N 769-4267
Dishwasher working fine again.
Nov 15, 2011 | Dishwashers
When I start my dishwasher the check water light keeps comming on. Also the salt light so the machine does not go through its cycle. Can you please advise me the best course of...
Hi, if your unit is getting good water pressure then the problem is going to be your flow meter which is the device that measures how much water is coming into the unit. If it doesn't detect enough water coming into the unit, the dishwasher will hault and give you check water light error. When the error comes up look at the water in the bottom and see if you have enough water in the bottom for a cycle. If not then your flow meter is fine and your unit truely isn't getting enough water which means that either your house isn't giving good water pressure to the dishwasher, or the electronic water valve that connects to the water line from your house is bad and needs to be replaced....
Jun 21, 2011 | Bosch 18 in. SRS56L08 Logixx Slim-Line...
My dishes are not getting clean, the cycle seems to leave them covered in bits of detergent and a white hard film. We've had it for three years, and this just started about a month ago
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Sep 02, 2010 | Kenmore 15872 Dishwasher
We have a Blanco BFDW 650S dishwasher approx 6 years old. We have been quoted over $450 to replace the inlet valve. Is it worth spending this on a machine this old? Am I being overcharged for this work as...
When you buy Bosch, you buy quality, quality costs, it is that simple. That price for you valve is a bout normal, but there are other consumables that are used as well, as travel, and labor. etc. You need to contact your Bosch agent in your local area and inquire there, they will direct you to a properly trained professional, again, which one must pay for. If you want to do it yourself, it is indeed possible, what one man can do, so can another, as they say. I will give you some links below. You also need a service manual they are hard to find, there are pay sites however, simply Google Blanco BFDW 650S service manual (enter) and look through listing for a PDF file to download.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Mar 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Sep 08, 2009 | Frigidaire 24 in. FDB126RB Built-in...
My Maytag dishwasher does not seem to getting water. After the cycle the soap is still in dispensor and dried up. I did not put in dispensor and placed them on the bottom and they were still there after...
When the dishwasher is nopt getting water into the machine, it means that either the floating sensor is stuck, or the water inlet valve is obstructed or defective.
" If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it."
From There's no water entering the machine
Sep 27, 2008 | Maytag Dishwashers
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
517 people viewed this question
Top Dishwashers Experts
