Question about HP Compaq Presario V6000T Notebook
Start - up not possible
When I plugged in the power to my HP, the power cuts and the laptop refuses to start.
I had called HP/Compaq about an issue with my laptop and was told that some models have been recalled so I'd suggest calling them about this problem to see if your particular model was one of those involved in the recall. Another solution that I have would be to try and plug it into another outlet. If that fixes it then there's something about the original outlet that needs to be fixed. If not, then try buying a new battery and/or adapter (charger). Hope I helped!
Posted on Jan 11, 2009
ACER ASPIRE ONE
Unplug the computer, hold the power button down until the laptop shuts down, then remove the battery. Plug in the charger, and try powering up. If all is okay, shut it back down, unplug it, and reinstall the battery. Then, plug it in and let it fully charge. Restart it, plugged in and with the battery installed. Good luck.
Apr 06, 2014 | Acer Aspire One PC Notebook
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
Will an E-Systems 2512 Laptop refuse to start if its the battery is defunct
Take the battery out and try starting it with the power cord only. If it starts then there is your answer. If it doesn't start then either your power cord/charger is dead or your motherboard is.
Jun 19, 2012 | Computers & Internet
Hp pavilion Dv 7 won't power on even when the lap top is charged.
Pull the battery and plug it in to the wall (in other words rule out the battery). If it still refuses to come on, check out this troubleshooting link:
http://www.techspot.com/vb/topic55208.html
Jan 15, 2012 | HP Pavilion dv7-1130us laptop
My system is refusing to boot
Detach the battery and attach it again, with the power cord unplugged, then plug it again, verify if is charging, if not take it to tech support, if it charge and have power, If power up but dont boot, try using the F8 key and try to enter in repair mode or safe mode. if can enter on repair computer (only vista and win7) use the start boot repair utility.
Mar 29, 2011 | HP Hewlett Packard Compaq 6720s Laptop...
I own an Acer Aspire 8930G, and as of a few weeks ago, it will not power on. At first I thought it was the AC adapter at fault, as the wire on the side that is inserted into the laptop had a small cut in...
Yes. The laptop will work with just the AC adapter plugged in. You can remove the battery from the laptop to check whether the ac adapter will turn it on.
If it does power on the laptop without the batter, then, you should purchase a new battery for your laptop.
CARLO
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 02, 2011 | Computers & Internet
Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
Sep 06, 2010 | HP Compaq 6735s Notebook
I hibernated my hp laptop and it refuse to come on again
Normall hibernation can resume from a selection of key / mouse touches.
Some of the HP's resume from the power button even though it is lit.
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Please I need help. I was using my Hp laptop to play music when it went off and refuse to restart. I removed the battery and re-inserted it again but it still refuse to start then I observed that there was...
Sounds to me like you need a new battery. There are a couple of other things it could be (i.e. the ac power cord) but it is most likely a battery-related issue.
Mar 09, 2009 | HP Compaq nx6110 PC Laptop
HP Compaq Presario V6000T Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
