Question about Acer Aspire 5610-4648 Notebook
Problem in booting then only mouse pointer display on the screen
I have Acer Extensa 4620 z, I connect it to external screen, but no display to external screen, after many times of pressing FN + F5 keys
external screen has worked, but windows ask some quastions related with external screen, I don't remember what I was answerd..!! then the diplay of external screen and internal screen disappeared,
after I switched off the power, then when I switched on, the list of booting appear on the screen, after I choosed save mode or any other mode ( save mode with network..command prompt... last recently good...normaly windows..etc ) booting is not complete and only the pointer of mouse is appear on the black screen, knowing that windows vista is the operating system and I try to restore system using the item -Repair computer- from the list of booting, but no way from the repair program of acer extensa, to use the DVD CD restore disk.
Please would you help me to solve this problem.
thank you very much
    Scholar:
  • 86 Answers
Sounds like you messed it up well!
Suggest you cut your losses and just reinstall the system afresh
but first try booting from the install DVD and going through the process until you reach the options to install or repair
Select Repair and let the DVD try and fix it
With Acer I think you press F11 or F12 when booting to get the one time boot choice.
When you have it just select the DVD player the disc is in and let it do its thing
Posted on Dec 10, 2008
Is Acer Extensa 4620 Notebook support 1tb hard disk
If it is Win7 and is partitioned to two 500Gb or three 330Gb drives, I see no reason why not but it will run very slowly!
Feb 01, 2014 | Acer Extensa 4620 Notebook
No display in acer extensa 4620
Hi There,
Check the below link that might help you to diagnose the issue:-
http://laptopturn.com/acer-extensa-4620-wont-turn-on-wont-boot-no-display-black-screen-problems/
Hope this will hep to diagnose the issue if it is VGA cable that is faulty of something else.
Jan 27, 2018 | Acer Extensa 4620 Notebook
Screen is blank? can you check this computeR? exentsa acer model #jalao
If your system seems to be going through its normal boot routine, look at the screen from several different angles. If you see 'ghosting' then it is likely the display backlight or the inverter for it that has failed. If you have, or can borrow, a standalone monitor, plug it into the VGA port of your notebook. If you still see nothing, it may be only that the external port must be turned on in your CMOS setup but the external monitor should at least show text during the boot routine.
Apr 17, 2010 | Acer Extensa 4620 Notebook
ACER EXTENSA 4620-4605 model screen problem
If you wiggle the screen and it comes back, then it is not your Video card. Probably just a loose connection with your LCD cable to the LCD screen. Although you may also need a new screen/cable.
The weird thing is that it "fades" out... which would indicate a bad screen to me.. but securing the cable is alot cheaper to try first.
Completely rule out your graphics card by connecting your laptop to an external monitor... if it works fine for a long period of time then your card is fine.
Good Luck.
Sep 06, 2009 | Acer Extensa 4620 Notebook
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
Acer Extensa 4620 Takes 3 Minutes to get past Cmos screen
goto bios by pressing F2 or Del while booting...
then in boot priority change first boot device as hard disk...
Jan 15, 2009 | Acer Extensa 4620 Notebook
Acer Extensa 5620Z split screen error
Re set the video cable inside the machine.
AKA pull it out And put it back in should work.
Jan 07, 2009 | Acer Extensa 4620 Notebook
Blank screen on start up on Acer Extensa 4620
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Acer extensa 5420 help!
i need hilp fof my webcam
Jul 24, 2008 | Acer Extensa 4620 Notebook
Acer extensa keyboard and mouse not working
Hello
I have acer extensa 4620-4605 notbook. When I bought it everything was working very good. Now I am facing some problems related with key board. The two extra keys for euro and dollar above the arows are not working. I am unable to understand how to overcome this problem. Please help me in this regards.
yogendra
ykmnsc@gmail.com
Acer Aspire 5610-4648 Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
