Question about Refrigerators
Fridge no turning on - Refrigerators
  • 1 more comment
  • mattcouk Dec 10, 2008
    Hi, sorry i thought i left a more in depth description than that! The fridge light comes on, and the compressor comes on periodically for a short time. but not very often. It does cool, but for such a short time. The fridge is basically at room temperature
  • mattcouk Dec 11, 2008
    I don't understand. Sorry I am new to this.
  • dwilkins30 Apr 01, 2009
    Fridge not turning on
    There is power - lights/beeping working. Loud humming (from compressor?). They have replaced the unit & this one will not cool. It has been on for 24 hours. All my food is ruined.
    Genius:
  • 1,122 Answers
Do you have power?is the compressor running,is the lights comeing on inside,let me know more so i can help-mike
Posted on Dec 10, 2008
  • MIKE major Dec 11, 2008
    thanks for not letting me solve your problem ,your on your on-mike
Fridge in off how to turn on
I'm not sure of your exactly fridge model, but if you have a fridge with an electronic panel, there should be a On/Off button. Press the button and wait until you hear a noise (keep on holding for some good seconds). The panel will than show OFF mode. Also - the fridge engine will turn off, and it will be really obvious as it powers off.
Aug 11, 2014 | Electrolux Refrigerators
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Fridge Icing Up
Sounds like you have a defrost Prob. Take back cover off. Turn defrost timer in to defrost mode you will feel a click. timer may be located in fridge. ceiling or back wall if not there check bottom of fridge. behind kick plate or in back bottom of fridge. by compressor. See if heating element gets hot if not check for 120 volts at heater and defrost thermostat ( Terminator ) if not check defrost timer if you do have 120 volts check for 120 volts at heater terminals if no voltage or weak voltage replace terminator if you do have good voltage replace heating element. When ice builds up the fridge. starts to get warm turn off for 24hrs turn back on fridge. will run OK till ice builds back up.
May 22, 2010 | Refrigerators
My dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
May 14, 2010 | Dometic RM2852 Refrigerator
I have a bosch fridge /freezer ksu 44 and there has been crackling sounds coming out of it and now it seems its freezing in the fridge part as well. There was water on the bottom tray which i cleaned every...
try this first :
turn your thermostat down first until the fridge stops .
turn the thermostat back up only a quater of the way and wait to see if the fridge turns on and off as usual .
if it does , the thermostat is ok .
if it does not , i believe the thermostat is dead .
in regards to the ice in the fridge part , you maybe have the fridge turned to far up but let me know how you go .
Sep 29, 2009 | Audiovox Bosch 718 World Cellular Phone
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Eaton viking fridge needs to be colder
when you turn the knob anticlocwise it will be warmer and clockwise will be colder. some thermostat switches when you turn it anticlockwise untin it clicks turns off your fridge completely.
Sep 06, 2009 | Refrigerators
Fridge does not come on after power failure restoration
If you don't have a surge protector for your appliances, the sudden power surge can affect the electrical's on your fridge which is probably why it doesn't go on. Also, it sometimes pays to turn the power off at the wall then wait 10-20 minutes before turning the power back on.
Nov 17, 2017 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
