Question about LG Studioworks 700S 17" CRT Monitor
I need to get monitor back to original size. it appears as though someone has pulled the 'startup' too0l bar over to the left. how do i get it back? Jo x
    President:
  • 2,110 Answers
Just click on any empty space on start up tool bar and drag to buttom of ur screen...
Posted on Dec 10, 2008
What is the origin of the expression "to pull someone's leg"?
The Interesting Origins Of Common English Idioms: "Pull someone's leg"Definition: Joking or fooling with someone.
Origin: To pull someone's leg had much more sinister overtones when it first came in use. It was originally a method used by thieves to entrap their pedestrians and subsequently rob them. One thief would be assigned 'tripper up' duty, and would use different instruments to knock the person to the ground. Luckily, these days the saying is much more friendlier, though being on the end of a joke might not always be fun.
Nov 04, 2013 | Computers & Internet
The user profile service failed the logon. user profile cannot be loaded
Anyway.. If you can, follow these steps. They might help! If not, give me a bell! It looks complicated, but it's very easy.
Also, before this happened, did you trying doing a Windows Update? If so, that was the cause, especially if it failed. I don't know why it locks the account, however.
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2803d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair.jpg
B) Add .bk to the end of the numbers. (See screenshot below)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2804d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair_bk.jpg
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 828x303.2805d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repar_bak.jpg
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 836x303.2737d1221837039-user-profile-service-failed-logon-user-profile-cannot-loaded-repair_reg2.jpg
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click on OK. (See screenshot below)
2738d1202983360-user-profile-service-failed-logon-user-profile-cannot-loaded-modify_refcount.jpg
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
2739d1202983366-user-profile-service-failed-logon-user-profile-cannot-loaded-modify_state.jpg
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
Mar 14, 2013 | HP Computers & Internet
I am using the Asus VH236H for video game playing on my playstation 3 and xbox 360. I was playing marvel vs capcom 3 last night and notice a red vertical bar appear on the left hand side of the screen and...
Flat monitors work on a grid method, if one of the grid is failing it creates a horizontal or verical line. its not something you can fix, so send it back.
Mar 17, 2011 | ASUS VH236H 23 inch Monitor
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
Start up screens are off to the left.
There's nothing wrong with the monitor. Monitors remember the settings for different video modes, including horizontal position. The video mode used when the splash screen displays is a size almost every monitor can handle. Then the mode switches to whatever you've set once Windows finishes startup. As long as the display is normal once Windows is running, you really don't need to be concerned.
If you want to correct the problem, you need to put the monitor into the same resolution and use its menu functions to adjust the size and position. Try pressing F8 when the machine boots to get into the Windows startup menu. This will probably also be shifted, so you can adjust the settings while the menu is being displayed.
Apr 16, 2009 | Computers & Internet
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Display size / resolution
Hi thanks for this but no to no avail. There is nothing wrong with the display itself - everything works but the problem is that the VIRTUAL size of the screen is 1500 x 950 instead of 1440 x 900 if you get my meaning. I wish i could find a way to shrink back the virtual screen size to 1440 x 900 so that it fits the exact physical screen. ie. if i was to play a DVD on full screen i would only see 95% of the picture because the virtual screen is larger than the display. And the virtual screen would move right if I shifted my mouse to the right edge. Still puzzled.
Sep 19, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
LG Studioworks 700S 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
