Question about Microsoft Xbox 360 Console
My computer restarts itself at the most inopportune times.
I take college courses online and my computer decides to shutdown and restart itself in the middle of an assignment causing me to lose everything. Can you help me?
    Sergeant:
  • 306 Answers
Try to check in the BIOS of your system if you have activated the wake on lan, of your NIC (network card). If you have ypur computer connected to a router and you it on, sometimes there is some network activite that start up
the machine if the wake on lan (WOL), is active.
Posted on Dec 10, 2008
  • AbdulRahiman S Dec 10, 2008
    or else the system might be overheating. It will have a temperature overload which shuts it down when it reaches a certain temperature.
    Hardware issues that cause computer shutdowns :
    Heat - if your computer or any major component (memory, hard-drive, cpu, power supply) is overheating the system can shut down without notice.
    Electrical problem - if any components on the computer have a short or voltage problem the system can shut down without notice.
    Software issues that cause computer shutdowns :
    Driver fault - if a major software driver (software that controls hardware) causes a fault the system can shut down to prevent damage to the hardware.
    mostly shut downs happen for various reasons but one is when it gets over heated, it is often a sign that something is going bad, could be a fan has stopped running or the power supply is going, or the inside of the pc is full of dust bunnies clogging everything up. When was the last time you took the side panel off and cleaned out the dust? That is a must do chore, get some canned air and carefully blow out the dust, make sure you have the power off of course and ground yourself by holding on to the metal frame of your pc case or get a little cheap antistatic bracelet at any electronics store for a couple bucks.Malware can make it do that too, I do not know what you mean when you say you ran every kind of cleaner imaginable, do you mean antispyware programs? or do you mean registry cleaners, if it was registry cleaners that could be a problem. Listing what you did recently might help.
    I suggest getting superantispyware free and updating it, running it and let it clean what it finds.
  • 345 Answers
Is this on a computer or an Xbox 360? Either way I would check the motherboard or CPU fan and see if either has a problem. On the motherboard, I would check for capacitors that have a bulge and a bit of dried fluid on the top of them. As far as the CPU fan if this is a computer I would check the BIOS settings and make sure the fan is set to normal or always. (newer motherboards control the fan by the bios settings.)
    Guru:
  • 859 Answers
Replace the power supply.
  • Glenn Rogers
    Glenn Rogers Dec 13, 2008
    It was a bad power supply? That's what makes the most sense, xbox, wii, pc, laptop. They exhibit the same characteristic symptom.
    Regards,
    Worldvet
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, if on the re-Start, the laptop behaves normally, then the problem is your battery. A few ideas you can try:
  • run the laptop without the battery, just the AC adapter only;
  • try to minimize electrical power consumption such as playing a music CD;
  • reduce USB devices connected;
  • one of the unnoticed power consumer on a laptop is the WiFi, see if there is a power reducing option only if your WiFi router is pretty near.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 10, 2008
    Some other things to consider:
    • is the laptop well ventilated;
    • are the exhaust vents of the cooling fan clear of any obstruction;
    • is the CPU fan turning at all;
    • an external cooling fan might also help if problem is determined to be heat related;
    • an aftermarket docking station with additional cooling fans and battery might be of additional help.
    Cheers.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
I have a pc that the screen stoped working. so I have it connected to my phillips tv via HDMI, and it was working good like that. but know every time I shutdown and restart I get "prepare boot to...
Your tv will only work when it is hard wired to the computer output. With no connection, of course, it is not going to work!!!!!!!!!!!!!!!!!!!!!!!
Aug 25, 2017 | Computers & Internet
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | HP Pavilion 110-1030NR Notebook
System shutdown message pop up and shut down and restart computer
Jan 22, 2010 | Computers & Internet
Each time I hit shutdown, the computer restarts
there may be a problem with the power options of your notebook
go to control panel>>power options
click advance tab
there will be a option
"when i press power button on my computer"
there will be a drop down text box select shutdown
this will solve your problem
Dec 29, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
My itoch makes my computer turn off
try using another data transfer cable,it seems there a short connection on your data cable.when this happens the pc will automatically shutdown and restart.if it still dont solve the problem then check the terminal of the itouch for a possible short circuit.
Dec 21, 2008 | Apple iPod touch
Mt 1999 concorde lxi shuts down and after 1 to 4 seconds restarts
it sounds like your computer wont take your key. best thing you can do is take the car to the dealer.
Dec 19, 2008 | 1999 Chrysler Concorde
Unable to restart
Are you saying that you cant restart or shutdown your computer using the software menus, but using the reset or power switch does work? What Operating system?
Nov 29, 2006 | EPoX EP-8K7A Motherboard
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
