Question about Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950 prints green on photo paper
My canon i9950 has suddenly started printing with distinctly green overtones on inject photo paper. It prints fine on plain paper & the nuzzle is clean.
  • 1 more comment
  • Anonymous Dec 15, 2008
    I have the same problem . I have tried various photo paper and, including Canon paper but no change. Prints fine on plain photocopy paper, but green on glossy or matte photo paper. I have cleaned the nozzles.
    CSB
  • ctscr Mar 11, 2009
    My i9950 printer prints cyan cast on photo paper but seems to print OK on plain paper.
    i would appreciate any help.
  • Mike Box May 11, 2010
    I had the same problem 3 years ago on mine and got no useful assistance from Canon tech Support other than "a fault is likely... ... send for service". However the fault apparently rectified itself, but has now started recurring. I have tried altering settings but can only get "normal" looking prints by selecting "plain" paper - selecting "matte" or "glossy" results in prints with distinct cyan colour cast. All prints remain dense and sharp and nozzle check confirms all inks can print OK. Not much consolation I know but seems to be a similar fault.
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Posted on Aug 03, 2009
I have solved the cyan cast problem with my i9950 printer. The fault lies in the fact that the ink absorbant pad in the base of the machine is saturated with ink and in the printer mechanism there is a fan that pumps the excess ink to the ink pad. The result of this is that ink is being vaporised in the machine and it gets coated all over the circuit boards. Some of the circuits are so close together that ink joins them up, especially at the connectors. I removed both circuit boards and cleaned them with proprietry cleaners, re-installed and the problem was gone. I have now removed all the ink pads in the base of the machine and also eliminated the ink pump. I now have a small hole in the side of the printer for a small tube. The waste ink now travells down the tube and into a container to be emptied separately. Hope this helps.
Posted on Sep 28, 2009
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Nov 27, 2009 | Canon i9900 InkJet Photo Printer
Canon i9950 inkjet printer, keeps showing paper jam even though nothing there. If I turn it off and on, it prints anything from 1 to 4 pages before error message paper jam again. Just going round in...
Maybe it's just one small paper.
If it's on guarantee, take it to store, and describe the problem like this:
"Cant print. Don't know whats going on!"
So they don't charge you ;)
If it's out of guarantee, try to open all parts until you see the small paper.
Or it could be the sensor (piece of plastic) that was jammed, or get jammed when paper pass. Take a good look on that too.
Aug 27, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
I9950 Canon printer with message 'Waste ink absorber almost full.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power
button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release the Power
and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights
alternately in orange and green, starting with orange.)
4) 4) When the LED lights in green, press the Resume/Cancel button 4 times to reset 'Waste ink absorber'.
5) Press the Power button to execute.
Jan 21, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Service manual vanon i9950
button.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in either orange or green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
Time(s) LED
Function
Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See Section 3.5 Verification Items, (1) Service test
print.
2 times Green EEPROM information print See Section 3.5 Verification Items, (2) EEPROM
information print.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings After performing step 5), and follow the Destination
settings procedures.
6 times Green Print head deep cleaning
7 times Orange Media sensor correction After performing step 5), and follow the Media sensor
correction procedures.
8 times Green CD-R test print Not used in servicing
9 times Orange CD-R print position
correction (horizontal)
10 times Green CD-R print position
correction (vertical)
11 times
or more
Return to the menu selection
For full Service manual I've uploaded it here:
http://www.megaupload.com/?d=BLC9L7OU
Mar 24, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Printing
I wonder if it is in fact a printer problem? have you tried different programs?
Aug 18, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Canon BubbleJet i9950 InkJet Photo Printer Logo
683 people viewed this question
old marine
old marine
