Question about Gateway 7330GZ Notebook
Unable to brose web because my laptop (gateway450rog) lack driver
Under the hardware device manager option, precisely "other devices", the ethernet controller, network controller, PCI modem and VGA compatible drivers are not functioning. I tried updating the drivers automatically but couldn't. Can someone help me out there?
  • 117 Answers
You can download latest drivers here
Posted on Dec 10, 2008
I have an ACER travelmate i am unable to find the LAN after installing the drivers also
If a device doesn't show in device manager, look for it as a "hidden device". These devices usually are detected by the OS, but are not functioning.
Generally, I've found that there is a hardware fault if the typical scenario of uninstalling the driver & reinstalling doesn't work. That's when you see your hardware end up under hidden devices. You'll likely need to replace that hardware. For dead LAN ports on laptops, they do make a USB-to-LAN adapter.
Open device manager>and check the menu bar items>find "other options">show hidden devices. It's usually clustered with the other "views" of showing by IRQ, etc.
FYI
Sep 20, 2011 | Acer 91.AB370.001 Network Adapter
How to download or detect my webcam
1. Connect your web cam
  • Attach all power cords (e.g. laptop and/or web cam).
  • Plug your USB cam directly into your computer (do not use any external USB hubs). Turn your cam on
  • As long as your web cam and computer hardware are working, Windows should detect it!
2. Open Device Manager
  • For Vista
    => Click Control Panel. If you have Control Panel Classic View, click Device Manager
    => Click Control Panel. If you have Control Panel Home View, click System and Maintenance->Device Manager
  • For XP
    => Click Control Panel->System, then Hardware tab, then Device Manager button
3. Find your web cam in Device Manager
  • Understanding Device Names
    => Windows provides user-friendly device names to accomodate us humans. As far as Windows is concerned, the device name is simply a comment!
    => It's those cryptic Device Identification strings that really identify a device
    => Device Manager displays whatever device name it happens to find in the device driver
    ...==> If Windows finds NO device driver, your web cam may be named "Unknown" or "Other" device
    ...==> If Windows finds the WRONG device driver you may see your web cam with the WRONG device name
  • How to find your web cam
    => While your web cam is connected, look through all of Device Manager for devices with a yellow icon (probably a yellow question mark)
    => Be certain to expand the USB category to check all devices listed under it. Also, be sure to also check if category Other Devices appears in Device Manager and look under it as well
    => Your web cam will appear as a device with a yellow icon (probably a question mark)
    => Click on thumbnail to see the full sized image
  • How to verify the device you found is your web cam
    => Your web cam device will only appear in Device Manager when the web cam is powered on and connected
    => Disconnect your web cam. Verify the device you had found is no longer displayed in Device Manager
4. Find your web cam's Hardware Ids
  • In Device Manager, select your web cam device, rt click Properties. Click Details tab
  • Select Hardware Ids from the pull-down. You'll see a list of one or more Hardware Id strings
5. Search for a driver based on Hardware Id
> Update 1/26/2011: To avoid a common mistake, don't confuse the number zero with the letter "O". IDs may contain zero but NOT the letter "O"
The best driver will match the Hardware Id at the top of the list. The next best driver match will match the next Hardware Id on the list, etc
  • Start by searching for the Id at the top of the Hardware Id list
  • If only due to how different search engines work, recommend you cut USB\ from the search string
    => Example: If the Hardware Id is USB\VID_093A&PID_2468&REV_0001 search for VID_093A&PID_2468&REV_0001
  • You can start by clicking Search at the top of your TechSpot window to search TechSpot first
  • For more help on how to search for a driver using the webcam's Hardware IDs see this post
Feb 26, 2011 | ASUS Eee PC 900 Notebook
My mouse on the laptop is locked it wont move
click start control panel administrive tools computer management device manager scroll to mice and pointing devices + to expand right click you will the options to update drivers software, disable, uninstall scan for hard ware changes and properties select properties you will see more tabs,generaldriver,details,and power management.
select the driver tab you will have similiar options driver details,update driver,disable and to uninstall
you might have to uninstall the mouse and its drivers then reinstall them
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | Computers & Internet
Unable to install web cam
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 19, 2010 | Maxdata Prolynkz World PWC-010 Webcam
Dell Latitude C600, Ethernet adaptor NOT FOUND
Visit the Dell Web Site.. Use the Service tag on On under side of laptop.. and All Drivers are on the Dell Support Web Site!
Oct 09, 2009 | Dell Latitude C600 Notebook
I don't know what kind of cam I have?
  • For Vista
  • For XP
    ...==> If Windows finds NO device driver, your web cam may be named “Unknown” or "Other" device
    => Look if a device category Other Devices. Also, be certain to expand the USB category to check all devices listed under it
Aug 08, 2009 | Computers & Internet
I had to reformat my laptop and now I cannot get ethernet to work
you need the drivers for those devices marked with yellow --"yellow"ethernet
controller will not allow to access the web to download drivers to solve your problem--options are:- use the "original" driver disk that came with the laptop or download to another pc/laptop and transfer drivers using usb key.
Apr 27, 2009 | Dell Inspiron E1505 Notebook
My laptop motion eye
Please check in the Device Manager under "Imaging Devices" whether the "Web cam driver is listed". If the Web cam driver is not listed then install the web cam driver either using the Recovery Discs or from the location "C:\Drivers". Please do restart the Computer after installing the driver. Even if the web cam driver is listed under the "imaging devices" in the Device Manager then right click on it and unistall then restart the Computer and reinstall it. Next, use any video utilities such as MSN or any other to check if the web cam is working normally. It's required to configure web cam in the utilities to be used with any other utilities.
Apr 03, 2009 | Sony VAIO TR1MP Notebook
I reinstalled Windows XP on my laptop and don't know what etherne
You should first check device manager for any issues with Network drivers.
Start--> Run --> devmgmt.msc
This command will launch "Device manager" window.
If you see a Yellow exclamation mark in device manager for NIC, follow the following steps to identify the card that is installed on your computer.
  1. Open Device Manager (Right-click My Computer>Properties>Hardware>Device Manager)
  2. The hardware whose drivers are missing will appear as Unknown device, so it’s easier to locate the device.
  3. Right click on the unknown device and click on Properties.
  4. Under the Properties window click on Details tab and select Device Instance Id from the drop down box.
  5. You should see a code similar to this
    PCI\VEN_8086&DEV_27DC&SUBSYS_30868086&REV_01\4&1E46F438&0&40F0
  6. The portion of the code highlighted in RED is the Vendor ID and the portion highlighted in GREEN is the Device ID. In this example:
    Vendor ID = 8086
    Device ID = 27DC
  7. Once you have obtained both the IDs, proceed to www.pcidatabase.com . There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
After you find out the information about the device and the manufacturer of the device, you can visit the manufacturer’s website and download the corresponding device drivers.
Mar 23, 2009 | Dell Precision M20 Notebook
Gateway 7330GZ ethernet controller
you may have tried this but go to device manager and uninstall the network device and then reboot the found new hardware wizard will show up and the do not let it look click on have disk and point to where the drivers are located and if it says driver not digitaly sign install anyway should work
Jul 31, 2008 | Computers & Internet
Gateway 7330GZ Notebook Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
