Question about Brother SX-4000 Typewriter
I get only m or L
Ok, her it is, my typerither was droped and it started typing the wrong letters, I did not know what to do to fix it, so i opend it up, yes i now not a smart move. I did get it back together right( i hope):I. Then i found this web site. so know its only typing one letter no matter what i press m m m m depending on how i turn the daisy wheel. Did i breke it, can it be fixed.
    Problem Solver:
  • 20 Answers
Make sure the dasiy wheel is locked in place, lever is on right side of ribbon holder.
Posted on May 01, 2007
SOURCE:
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
7040 Typewriter: when i start typing it types wrong letters...........
Check the pitch slide switch in the left of the keyboard, it should be in 10 or 12 if it is slide it up and down they do get dirty.
DickyO
May 16, 2010 | Swintec 7040 Typewriter
Door window
this is a common problem with the accord what happens is the window starts sticking in the window rubber one one side more than the other and bends the arms on the window mechecanism you can bend these back and take the window rubbers out of its frame clean them put them back spray them well with wd spray but the problem is are you feeling lucky as the perminant souloution to the proble is to replace the window rubber and window regulator is the name of arms on the window mechecanism if you intend to replace its not as bad a job as you think all wires on your door pad are plugs so you cannot go wrong as far as the regulator it amatter of about half a dozen nuts yates210456
Sep 22, 2008 | 2001 Honda Accord
Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Aug 06, 2008 | Brother ML-500 Typewriter
Instruction manual does not explain how to activate the calculator on the Toshiba Satellite P200D/P205D Series laptop.
Dear,
Just type CALC on run command at Start menu. Calculator will be opended on screen.
Click on START
then click on RUN
then type CALC
press OK
Regards
Apr 28, 2008 | Computers & Internet
Printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Apr 28, 2008 | Brother GX-6750 Typewriter
TYPES WRONG LETTERS
everythin is ok,you by a new wheel with letters and that wheel is for european market ,and y -z ar on the other sides
Feb 04, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
Brother SX-4000 Typewriter Logo
105 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
