Question about Epson Printer
I have to replace a cartridge for Epsom 400 but cannot get the carriage to stop in the right place to get old cartridge out
    Problem Solver:
  • 8 Answers
Turn off the printer and drag the cartridge trag gently to the right place. and fix the cartridge. But this is not the best way. First try swich off the printer from  power for around 2 mins and then try.
Posted on Dec 10, 2008
I have a Epsom we 3620 with the error 0x f1 how do I fix it
This relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes.
If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides.
Epson WorkForce WF 3640 mechanical issue during initial setup errors 0xF1...
May 08, 2018 | The Office Equipment & Supplies
6510 Model. How do I change the in k cartridges
Step one: Open the All-in-One
  1. Press the Power button ( ) to turn on the product, if it
    is not already on.
  2. Open the cartridge-access door. The carriage moves
    to the center of the product. Wait until the carriage stops moving before
    proceeding.
    Figure 1: Open the cartridge-access
    door
Step two: Replace the old cartridge
  1. Press in the tab on the front of the cartridge,
    and then pull it out and up to remove it from its slot.
    Figure 2: Remove the cartridge from its
    slot
    CAUTION:Do not lift the gray latch next to the
    carriage to install the cartridges. Doing so can result in incorrectly seated
    ink cartridges and printing problems. The latch must remain down to correctly
    install the ink cartridges.
  2. On the replacement cartridge, pull the orange
    pull-tab straight back to remove the plastic wrap.
    Figure 3: Remove the plastic wrap
  3. Twist the orange cap counterclockwise to snap it
    off the cartridge.
    Figure 4: Remove the orange cap
  4. With the cartridge contacts facing the printhead,
    slide the cartridge into the correct slot. The color-coded icons on the
    cartridge and in the printhead indicate the correct slot.
    Figure 5: Insert the ink cartridge
  5. Press down on the ink cartridge until it clicks
    firmly into place.
    Figure 6: Press the cartridge into place
  6. Repeat these steps for each cartridge that you want
    to replace.
  7. Close the cartridge access door. The carriage moves
    to the right side of the product.
Aug 19, 2013 | HP Officejet 6500 Wireless All-in-One...
Would like instructions for installation of new ink cartridge in 6500A printer
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube Step one: Open the All-in-One
  1. Press the Power button (c01602202.gif ) to turn on the product, if it is not already on.
  2. Open the cartridge-access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding. Figure 1: Open the cartridge-access doorc01638336.gif
  1. Press in the tab on the front of the cartridge, and then pull it out and up to remove it from its slot. Figure 2: Remove the cartridge from its slotc01495178.gif
    CAUTION: Do not lift the gray latch next to the carriage to install the cartridges. Doing so can result in incorrectly seated ink cartridges and printing problems. The latch must remain down to correctly install the ink cartridges.
  2. On the replacement cartridge, pull the orange pull-tab straight back to remove the plastic wrap. Figure 3: Remove the plastic wrap c01493650.gif
  3. Twist the orange cap counterclockwise to snap it off the cartridge. Figure 4: Remove the orange cap c01495123.gif
  4. With the cartridge contacts facing the printhead, slide the cartridge into the correct slot. The color-coded icons on the cartridge and in the printhead indicate the correct slot. Figure 5: Insert the ink cartridge c01493652.gif
  5. Press down on the ink cartridge until it clicks firmly into place. Figure 6: Press the cartridge into place c01493653.gif
  6. Repeat these steps for each cartridge that you want to replace.
  7. Close the cartridge access door. The carriage moves to the right side of the product.
Jul 27, 2011 | HP Officejet 6500 Wireless All-in-One...
How do i stop the cartridge holder in the right place to replace the ink cartridges ?
In most printers the carriage come to the center when you open the top cover. Sometimes the carriage will go all the way to one side before returning the the center if you give it a min it should stop in a place where you can replace the inks. It it's not then you may have a problem with the printer.
Aug 31, 2010 | Office Equipment & Supplies
I have new cartridge for my epsom 300 but cant remember how to get the old ones in position to be removed
Make sure the cd-dvd tray is up, press the little button next to the power button. then look on the screen on the printer and scroll down to replace ink press ok and it should move the carriage a little way to the left so you can open the carrier to replace inks , put ink cartridge in press ok.
Hope this helps
Aug 22, 2010 | Epson Stylus Photo R300 InkJet Printer
How do I change the Ink cartridge in a Epsom DX 7450
Activate epson status monitor, if ink reach ink out, the message will appear. Then follow "How to..." Manually, turn on printer, and unplug power while carriage moving. Then move carriage by hand to replacement position. Replace ink tank, turn on printer.
Sep 20, 2009 | Epson Office Equipment & Supplies
How do i replace ink cartridges DX7450
You ve not mentioned which model of printer you are using, but in almost every printer if you open the top cover ink cartridges stop at a convinient place where they can be replaced. Alternatively you can shut down your printer and then try. Hope it helps
Aug 24, 2009 | Office Equipment & Supplies
My Epson SX 100 is low on the three colours but when I open the top to get to the Cartridge Bay, the cartridges are not stopped on the right place for me to change them with new ones. They are stopped on...
Have you pressed the ink button to move the ink carriage to the correct position? Press the ink button to indicate each empty cartridge and then move it into the replacement position.
If it doesnt move you could always turn the printer on and as the carriage moves across pull out the cable or switch off at the wall socket. The carriage can now be pushed into the correct position. Push it back fully to the right before turning back on.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Message on Epsom Stylus DX6000 reads E-02. How to fix?
E-02 is an ink cartridge error, possible causes incude faulty ink cartridge chip, incorrectly installed cartridge, dirty contacts, ribbon cable not fitted correctly to carriage or faulty CSIC board in the carriage.
Your first step would be to remove all of the cartridges and clean the contacts and cartridge chips with contact cleaner or alcohol wipes. Refit cartridges ensuring that they all click into place and check the ribbon cable into the carriage is secure.
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
I can't get the ink cartridge carriage to stop in the right place
It would help if you told us the printer make & model, however the easy way (for most inkjets) is to turn on the printer, when the carriage moves across simply pull out power cable or switch off at the wall socket. You can now push the carriage into the right position. Ensure it is pushed back the the park position before turning back on.
Mar 26, 2009 | Epson Office Equipment & Supplies
Epson Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
