Question about Cisco (1841) Router (cisco1841)
Console displays junk display what is the problem
Reena
  • 345 Answers
Make sure you have the settings on your serial port set to:
Speed - 9600
Data Bits - 8
Parity - none
Stop bits - 1
Flow Control - none
This should help.
Good Luck!
Posted on Dec 10, 2008
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
2002 F-150 supercrew My coumpas-outside tem.quti working.Were is the fuse?
The overhead display is powered by the same circuit for the overhead console, so if the vanity mirrors still work, chances are the fuse is fine.
Just in case, push the button a few times, to make sure the display is not turned off.
The overhead displays have a chance of the surface mounted resistors becoming unsoldered over time.
You can get one at a junk yard, or if you are good with a soldering iron, you can reattach the surface mounted resistors. Pull the overhead console down, and remove the display ( T10 screws holding the display to the console ). There are 2 plastic tabs holding the display together, release these.
On the back of the circuit board, you are looking for a resistor that looks like this :
Feb 23, 2010 | 2002 Ford F150 Regular Cab
Display
To troubleshoot sound without picture issues, follow these steps:
  1. Reset the resolution of the console to 640x480. To do this, start the console, hold both triggers, and then press and hold the Y button as the console starts. For more information about how to reset your display settings, click the following article number to view the article in the Microsoft Knowledge Base: 911059 (http://support.microsoft.com/kb/911059/ ) How to reset your Xbox 360 console display settings to the default display settings If you see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting. If you still cannot see a picture, continue to the next step.
  2. Disconnect the VGA HD cable from the display, and then remove the console power cord from the power outlet.
  3. Wait five seconds.
  4. Reconnect the console power cord to the power outlet, and then turn on the console.
  5. Reconnect the VGA HD cable to the display. If you can see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting.
Aug 08, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Overhead console (EVIC) seems dead
same problem. I finally solved it by buying a new circuit board with display from a junk yard for $35.00 and replaced it. they let me try it out there before i had to buy it. Works fine now.
Jan 20, 2009 | 2002 Jeep Grand Cherokee
Overhead console,LED does not work
with these overhead consoles if fuses are ok,the console is shot,have replaced many consoles in 2000 super dutys.have never had problems with wiring to console.
Nov 14, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Unlock n70 mobile's memory card
I m Akshay.I have nokia N72 mobile phone. I forgot my memory card password.so pls help me to unlock this.and i can not do format my memory card b'coz may i loose my important data....so pls guide me in this matter......................
Jul 03, 2008 | Nokia N70 Cellular Phone
Cisco (1841) Router (cisco1841) Logo
108 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
