Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Raynor 1245rgd navigator learn button blinks
Blinks 5 times, then 5 more. After a short pause it starts again. When the burtton is pushed the door moves about a foot. If it is pressed a second time, it returns that foot. Just replaced the worm gear and sprocket. Did I do something else?
  • 28 Answers
5 flashes on operator and the short movement on the door indicates a bad RPM sensor. try to unplug the unit for 30 seconds, if this does not reset the motor, replace the RPM sensor
Posted on Jun 09, 2010
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
What is the codes for a 95 dodge caravan 3.0 v6 it's blinks twice
The 95 Caravan is great for giving you trouble codes. However they are two digit codes. There should be a blink sequence followed by a short pause then another blink sequence (example 2 blinks, short pause, 3 blinks... Then 5 blinks, pause, 5 blinks which means no more codes. Turn key from off to run three times and leave in run and watch check engine light to count blinks. Disconnecting negative terminal on battery for 30 seconds clears codes.
Sep 09, 2010 | 1995 Dodge Caravan
Same as jasonvonk mar 15 2010 I get error code 37 after device and menu buttons pushed. red lite blinks 4 short pause and 4 short again Jim
37 is lamp or dmd failure. i don't find anything on 4 red blinks.44 error code which is 4 blinks, and then 4 blinks in disconnected DVI cable from light engine.
Mar 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking on learning indicator...push the remote or wall button nothing works...what happen?
If that LED is blinking a code let me know what it is. For instance 5 blinks and a pause then repeats. If it is just blinking randomly that is normal.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Sony Wega KV-32FS120 wont turn on (5 blinks)
Hi Simonbra,
According to the service manual. the 5 blinks is due to a defective IC on the M board, The defective part is IC001
I can send you the service manual if need be.
Mar 02, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
710 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
