Question about Casio Exilim EX-Z500 Digital Camera
Power turns off
When I turn the camera on the lens comes out, the operational light keeps flashing green and the lens goes back in. Battery is fully charged. Will work in play mode but not rec mode. Camera is less than 1 year old
  • Anonymous Jan 31, 2009
I was having the same problem... I put the camera in the cradle with it plugged into usb and then pushed play mode... the camera went to play mode and then i pushed and held the camera mode button while i was removing it from the cradle... it ended up turning on!!! i have no clue.. very weird
Posted on Dec 17, 2007
  • 374 Answers
I would first try taking ur memory card out and see if it will power up in the record mode then. If it doesn then that means that you have a bad memory card. If it doesn't turn on then you are going to have to send it in to have it repaired.
Posted on Jul 08, 2007
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
Sd10 elph green
I suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries. you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
Oct 11, 2008 | Canon Cameras
When I turn the power on, green power light comes on, lens comes out half way but then freezes and green light goes off, camera unresponsive. battery is fully charged and I have taken it out and put it...
Hi.
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Regards.
Aug 09, 2010 | Canon IXUS 960 IS Digital Camera
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Olympus Camedia D 535 lights are on but no one is home
hi,
Please check the battery if the battery is fully charged then the camera is not getting power properly from the batteries .
Feb 17, 2010 | Olympus D-535 Zoom / C370 Zoom Digital...
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Kodak Easy Share M873 suddenly not working
What happened is that the camera got turned on in your pocket or somewhere and the lens got jammed trying to open up. The problem is that the outer lens ring is not turning all the way and the camera doesn't fully load.
Solution 1: Put the camera into the charger, press the power button so the green light is flashing, unplug it from the charger. The camera will try to realign its lens. (You might have to do this a few times.)
Solution 2: Manually help turn the outer lens ring clockwise when it turns on.
Oct 29, 2008 | Kodak EasyShare M873 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Camera wont stay on, please help
Possible that the Lens Mechanism is out of sync. If its still within warranty just bring it in and have it serviced. If not I may be able to help you out but it requires dismantling the camera,..
If any one knows a quicker and easier way maybe they can post it here But as far as experience goes thats what happened with mine,
Hope this helps
Oct 12, 2007 | Casio Exilim Card EX-S600 Digital Camera
Camera won't turn on
Sep 26, 2007 | Samsung Digimax L60 Digital Camera
Casio Exilim EX-Z500 Digital Camera Logo
152 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
