Vibrating speakers even at modest levels. Have tried adjusting bass & treble to no avail. Panasonic TH 37PX80B still under warranty.
It appears this is an inherent problem with this model
Posted on Dec 11, 2008
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Hey there, I have JLB Creature II speakers, that have been working fine for nearly a year. Until one day, when the treble's maximum volume became a lot lower than before. The bass still rocks it up like...
Hi Nikita,
The problem may be with the internal electronics of these speakers, especially the sub-system that controls the treble. If they are still under warranty, you should talk to the dealer. If not, you should contact a technician.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | JBL CREATURE II Computer Speakers
What niles power amplifer would work effortlessly with my bose 901 speakers? i am trying to achieve a deeper bass and tonal level treble for my speakers even at a low volume levle thanks.
The 901 Active Equalizer comes with some bass and midrange adjustment for tayloring them to your environment and taste.
Your question is about personal preference, which none of us could possibly answer.
Since any amplifier worth its salt should just make the sound BIGGER without coloring it, your question is moot. What you want is NOT a quality amp. Maybe an equalizer?
Mar 21, 2010 | Bose 901 VI Main / Stereo Speaker
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Radio: panasonic cq-hx2083u
all radios do it these days so yes u must check if it has an rca line out for the amp
Oct 05, 2008 | Car Audio & Video
Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
May 14, 2008 | Onkyo TX-SR304 Receiver
Televison & Video Logo
Top Televison & Video Experts
