Sharp AL-1457 - L1 - Error Code
I read one of the threads where you participate and it seems that you know a lot about this kind of things so maybe you could give me some help on that. I got this printer from a company which simply bought a new one. The printer seems perfectly ok - just for some reason it shows the L1 error.
I opened and lubricated the printer, I can move the lamp carriage and it also moves by it's own when powering up the machine (coming a bit forward and going back quickly). Also the black sensor in form of a "u" fits perfectly together with the metal located where the home-position is. This printer has never been serviced or opened up and worked fin until it started with this L1 error.
Considering what I read it seems to me that the L1 error get's triggered wrongly by the printer.
Is there anything else I can do without spending money on it (I think it's not worse spending money on this machine any more however my grandpa would like to use it).
thanks and best regards,
Markus Pandur
  • 52 Answers
SOURCE: Canon pro9000 Carriage lift mechanism error [5110]
hi i am a certified Canon repair tech for this printer. this machine has a service bulliten for this problem and i have preformed the repair of this problem. the carridge lift cams are rotating faster then they should due to the wrong grease being applied to the part at the factory. this will require a Canon service center to repair because they is a special grease that needs to be used to slow down the cams. the best way is to contact Canon at 1-800-OK-CANON to locate a service center near you and they will repair the machine under the warrenty. hope this helps.
Posted on Jan 05, 2008
The Machine
  • 788 Answers
SOURCE: Epson LX-300+ Dot Matrix Printer Big Problem
If you mixed up where the sensors plug into the board then the printer will not be able to sense where the carriage is. Make sure the sensors are all plugged into there proper jacks.
Posted on Jan 15, 2008
SOURCE: Dell 3100 CN replace drum cartridge
Google is your best friend
jon_than21
  • 30 Answers
SOURCE: My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Posted on Jul 28, 2008
jaiku
  • 79 Answers
SOURCE: Scanner Position Error
hi i think this is carrage home position sensor problem. u check and clean the sensor and try it back. or any forign meterial blocking in carrage way.. pls check that also.. all the best..
Posted on Aug 18, 2008
My sharp AL - 1457D its not responding it only blinks 4
Hi, there is no error 4 alone it is usually followed by a H that is H4. Try to key in the following C Auto C Auto then enter 14 and press Copy key. If it was power low voltage , it will not re-appear but if it comes back then replace heater lamp and reset again.
Jan 17, 2011 | Sharp AL-1457 Black and White Copier
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Jul 13, 2010 | Sharp AL-1551CS Copier
Sharp al 1661 cs ..it shows System error(L1-00
I have posted a tip covering this code here on Fixya. Here is the link to it so that you may find a solution for your L1 code.
Good Luck and Thank You for using Fixya.
Jun 10, 2010 | Sharp AL-1661CS All-In-One Laser Printer
How to remove L1 fault
Sharp AL 1457 Flashes code L 1. I have read about the scan lock on here and have turned it to the unlock position but it still does not work. It is definitely turned to "unlock" and continues to flash L 1
I have switched it off and on again. I have unplugged it and then replugged in. No joy.
Any ideas please?
Apr 13, 2010 | Sharp Office Equipment & Supplies
Err0r l1 00
If you hear any cracking sound if you are not please clean all surface scanner area.Clean scanner sensor
unlock position .
Oct 07, 2009 | Sharp AL-1655CS Laser Printer
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
Jul 28, 2008 | Sharp AL-1217 Copier
Jun 23, 2008 | Sharp AL-1217 Copier
Scanner bar won't move
According to another source, the L1 error means "Scanner position error". Hope you find a solution, and not an expensive one.
May 16, 2006 | Sharp AL-1540CS All-In-One Laser Printer
146 people viewed this question
jasbo
jasbo
