Question about Nextar P3 GPS Navigation System
My nextar p3 freezes up
I have fully charged the unit and it will freeze up each time I try to use it it will go to the main screen and that is as far as it will go. I reset it and it will sometimes go to the next screen but then it freezes up again.I bought it for a gift and need it to be in working condition when I give it, can you help or do I need to return it?
  • 2 more comments
  • dennisgreen2 Jan 16, 2009
    unit freezes up when turned on. pushing reset button works initially then unit freezes up again.
  • Anonymous Mar 14, 2009
    When I set the tim & tap the check mark it does not stay it defalts to 12:00, What am I doing wrong?
  • snowyziggy Apr 16, 2009
    The Nextar P3 screen freezes while traveling, will work for a few minutes then freeze. If I turn it off or push reset button will work again for a few minutes. Works longer if sitting still but that doesn't help!
  • Anonymous Apr 22, 2009
    SAME PROBELM AS THE OTHERS. ALWAYS FREEZES. CANT EVEN SHUT IT OFF. HAVE TO USE THE RESET BUTTON/
Sounds like the sensitivity is whacked...can you hear the type sound. Mine does this sometimes and I solve it by using 2 thumbs and constantly push the settings icon, on each side. It will bring up the x for sensitivity...using the stylus tap gently and then twice to set. Hope this is what you were looking for.
Posted on Jan 25, 2009
Had a similiar problem. Goto the Setting Menu and choose your correct U.S. time zone along with the time. Then go into the Navigation Menu and choose Setting\Localization to select your Time Zone and Daylight Savings option.
Posted on Apr 02, 2009
Ihave Garmin nuvi 885. Suddenly screen is frozen. I start again and tochscreen work a few clic and screen is freezing again. I thought battery poblem and I purchase extra battery and arge fully and I tried...
You can update it with garmin webupdater or If its still under warranty send to garmin to be refurbished.I have the same unit and it does freeze up momentarily while the proccessor catches up.Only for a second though.Its a refubished unit as well.
Dec 23, 2009 | Garmin Nuvi 660 GPS Receiver
Why does my gps nextar show a red light and not turn on screen is black tryed pushing reset button but nothing happens
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 25, 2009 | Nextar P3 GPS Navigation System
My nextar GPS screen is flashing and won't turn on or off. I have had it for 1 week. X3-08 Please let me know. Tim Nextar X3-08
try tapping the bottom right of the screen with your finger, during the error or freeze up. > (gently)
Sep 03, 2009 | Nextar X3-08 Car GPS Receiver
GPS stuck up
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Jul 07, 2009 | Nextar X3-02 GPS Receiver
Curtis DVD-8009 picture freezes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 11, 2017 | Curtis DVD8009 Player
The screen won't light up on my nextar #P3 GPS
press the reset button on the back. i had the same prob.
Jun 09, 2009 | Nextar P3 GPS Navigation System
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
Nuvi 610 - External charging causes screen to freeze.
Don't disconnect it just because the screen freezes. This can happen if the battery is depleted too far, because the load is too great for charging AND running the device simultaneously. Leave it connected for 20 minutes or so, to see if the screen returns to normal appearance. If not, then you will be needing a new battery. Be sure to charge the new one BEFORE it is fully depleted. They are not NiCd batteries, so there is no need to fear ?memory effect". With NiMh and Lithium batteries, those days are gone, thank God!
Mar 30, 2008 | Audio Players & Recorders
Nextar HGPS35
I found this on Nextar support site. These units **** lots of problems being reported by many users.
Q: It (GPS) freezes on the "loading" screen. Why?
A: Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Jan 13, 2008 | Nextar X3B GPS Navigation System
Nextar P3 GPS Navigation System Logo
576 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
