Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Harmony Profile Electric Dryer
Just wondering if you might know the correct combination of buttons on my dryer that will give me the diagnostics? With this combination a screen will appear with blower RPM's, heating element temp etc.......3 buttons from what I remember the tech doing on in while he was here once.
  • Jeff scott Mar 09, 2007
    I figured it out myself by playing with the buttons, thanks.
  • Jeff scott Mar 10, 2007
    Absolutley!
    There are 2 types of diagnostics you can check. You must be in help mode for both:
    #1 Start/Stop and Help and the same time.
    #2 My Cycles and back at the same time.
    It give you a bunch of very useful info that GE hadn't had a clue about. They are useless!
I figured it out by myself, the customer care line was a joke and the manual is just that, for your average type of questions. It doesn't dig into technical issues at all. Thanks though, I really do appreciate your respnse.
Posted on Mar 09, 2007
  • 944 Answers
Try this - page 13 especially http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=DPGT750ECPL or call these guys - they might tell you. http://www.geappliances.com/service_and_support/contact/ hope this helps
Posted on Mar 07, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 10, 2007
    Any chance you could post the combination of switches in case a future problem on the same model comes up - someone might appreciate it, thanks.
  • Nigel Ridehalgh
    Thanks
Buttons not working/ screen options work fine
Problem for GE Profile Harmony DPGT750EC Electric Dryer Buttons not working/ touch screen & options works fine
Jul 11, 2010 | GE Profile Harmony DPGT750EC Electric...
Tip
GE Profile Harmony DPGT750EC (Electric)
Are you having problems with your GE Profile Harmony but don't know where to start to troubleshoot? Let the dryer do it for you, here's how:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
The system will give you a description of possible hardware failure and troublecode.
Replace the failed piece of hardware and plug your system back in. It will go through a boot-up sequence and verify that your machine is working once again.
on Apr 30, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile Harmony electric dryer
not sure of a reset button there maybe a fuse on the controller board What is the problem you are having??
Jan 16, 2008 | GE Profile Harmony DPGT750EC Electric...
How do you enter into the diagnostic mode
Dec 22, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony dryer sounds like a jet plane about to take off
KathleenA
I too have a GE Profile Harmony (Gas) Dryer that had started vibrating and making a loud noise. I removed the screws that held the filter and grill to the inside of the door frame and placed a mirror inside so I could see down inside the fan. I found that a softner sheet had somehow gotten around the filter screen and had lodged in the blades of the fan and had collected a fairly large amount of fine lint. The combination of the dryer sheet and the lint had created an out of balance condition that caused the dryer to vibrate and make noise (the forward cabin door has been closed and we're ready for takeoff!) I used a bent coat hanger as a hook and using the mirror to aim the hanger, I hooked the dryer sheet and pulled it out through the hole for the filter.
I hope I'm not too late to help you if indeed this is your same problem.
Theron
Nov 24, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer STOPS without pattern
You didn't state whether or not you were getting an error code. On this model if the blower motor exceeds 3000 rpms for one minute the dryer will stop. Usually this is caused by a clogged or pinched vent hose or vent itself. Check this out first. You can find the tech sheet under the consol. I believe it unscrews from the back and lifts up. This will give you detailed info on how to enter the diagnostic mode. If you cannot find the tech sheet, post back and the cat here will walk you through it. Catriver..post back.
Oct 24, 2006 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
177 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
