AV and S/Video channels not recieving any signal
Hi, I have a Hitchi plasma tv. Today the AV and S/Video inputs stopped working, I have my pay tv and dvd recorder plugged into them and they hae been flickering for a while and today they couldnt get a signal at all. I have checked the plugs and they are all connected correctly. Any suggestions?
  • 60 Answers
Yes go to service authorized because there wasn some electronik problem insede your tv possible to your dvd too
Posted on Dec 10, 2008
Tv is coming on but no picture is coming up and none of the controls will work.
This problems,could be ur incomming broadcasting signal wire like coaxel wire like connect to tv ANT. hole input. or AV wires connection Y,R,W to ur AV input holes or those HDMI cables connections to it output HDMI ports.Take every connections of wires that are connected to the tv like input/out connections wires out of the tv.Now leave only AC power source turn on the tv and see if u get a tv LCD screen signal statics of snows only and U see no broadcasting tv incomming signal and only statics noises on the tv LCD screen only.Yes,than this problems,than it is not the tv problems,these problems it could well be caused by ur pay cables,satalites or telecomucations compannies signals broadcasting coaxel wire to the those compannies pay recieving boxes.Tries to unplug the pay broadcasting signal box u are using for about an hour.This well reset ur pay box back to the original and factory setting.Now,Ur box the paying incomming broadcasting tv channels signal pictures should return.If not talk to ur paying tv broadcasting signals commpanies for a replacement of the box u are paying for.99% of ur problems,i'm seeing u having is a broadcasting tv pictures signals that imcomming to the paying box u have a problems.This is not a tv set itself problems.
Sep 30, 2012 | Computers & Internet
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Nintendo wii wont work with older model of Sanyo TV
how are you connecting the wii to the tv...through the rca jacks?  If so, you can not get to the input channels by the channel button.  On the remote there will be a button called either AV, Input, AV Video, Video, A/V, Input or something similar.  Hit this button until your tv goes to the appropriate av channel.
Mar 07, 2009 | Nintendo Wii Console
Recording from LG 42pc1dv plasma tv to LG v782w VCR
If it does this on all channels then the video on your AV out from the TV is bad.
If it only happens with some channels then this is Macrovision protection working which will not allow you to record premium channels and any that are using this protection.
Aug 10, 2008 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Can't figure out how to get s-video conections to work
to use s-video have to switch tv/video to video input
May 03, 2008 | Durabrand DWT2704 TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
