Question about RCA 27F650T 27" TV
Squeak I have a RCA TV 27'. When the TV is on and the TV is not muted, there is a squeak that comes from the back of the TV. It sounds like there is a cricket in the back of the TV. It is not coming from the speakers. When I move the cable wire around it will stop for a few seconds and then start again. Also, when we walk around the apartment you can hear it make noises based on us stomping on the floor. Please help!!
    Novelist:
  • 192 Answers
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Posted on Mar 04, 2007
SOURCE:
What do i do if the picture on my tv is good but i don't have sound?
Hello
Check first whether mute function is ON or not. If it is ON, make it OFF. If mute is OFF and still there is no sound from your TV, connect it to any other audio output sources, like an external amplifier or so, by connecting TVs external audio out sockets at its back and see whether there is sound output form amp. If not, make sure that the audio processing section circuits inside your tV is fulty. If there is soudn from amp, and not from the TV, check the speaker of the TV. If it is ok, then audio output section circuit of your TV is faulty, and need repair. OK.
Nov 30, 2011 | RCA F27252GY 27" TV
It has picture but no sound. It is like it is
in these situation tv like muted first you have to do is to check the speaker if having resistance sometimes it burned. if ok. change the amplifier ic.
Jun 09, 2009 | RCA F27442 27" TV
No sound
check if u have muted ur sound.....if so just push sound again and it will work......read ur instruction for ur set.....
Mar 28, 2009 | RCA 24V510T 24" TV
RCA tv when plugged in comes on and right back off
IF THE PICTURE IS TALLER THEN THE NORMAL SIZE IT MAY BE THE VOLTAGE REGULATOR. LETTING THE 130V POWER SUPPLY GO TOO HIGH.
Mar 20, 2009 | RCA 27V514T 27" TV
No sound - Samsung TXK2567
mute transistor may need to replace
Nov 13, 2008 | RCA F27615 27" TV
No sound
I know this sounds stupid but when was the last time you replaced the batteries in the remote? Can you use the TV volume button to change the volume up out of mute?
Sep 14, 2008 | RCA TruFlat 27F520T 27" TV
No sound on my RCA 27F650T
Yea I had that problem one day as well.. all you got to do is go into the menu settings and check the box for the Int speakers... that should do it
Apr 06, 2008 | RCA 27F650T 27" TV
Sound
Try unpluging the power from the tv for a several seconds.
Jan 16, 2008 | RCA TruFlat 27F520T 27" TV
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
RCA 27F650T 27" TV Logo
113 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
