Wt 540 hotpoint
Tried that already .Goes to rinse then stops.Do You still think there is a block.Or is it the board?
  • Washing Mach... Master
  • 3,463 Answers
You need to test the pump seperatey with a independent supply to determine that the pump is working, if it is and it still stops at the rinses, then you are not getting a supply to it, so could be a board problem.
Ensure it is not on rinse hold or crease guard (same thing)
Posted on Dec 20, 2008
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
Stay in high flats 4up low water pressure is there away of reducing the pressure in the hotpoint wt 540 washing machineso it will take in te water
If your water pressure is to high or even to low then just check the taps at back where hoses are fitted. Make sure they are fully open if pressure is to low, also make sure there are no kinks jn the pipes. If pressure is to high then just turn taps down a little.
Mar 12, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Hotpoint wt 540 will not run All indicator lights are flashing e-mail derek.emery@talk21.com
i had a greyhound that would not run so i kicked him up the *** that did the trick
Oct 03, 2009 | Washing Machines
Lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
May 22, 2009 | Washing Machines
Stoped during speen and since then no power. lights are off no conrol lights coming on. cheqed fuses etc, no imrovement. it is hot point AQUARIUS WT 540 16 months old
Hi, it sounds as if your capacitor has blown.
make sure the power has been disconected for at least 24 hours before checking this as it holds power for ages.
where the mains lead goes into the appliance it goes directly to the capacitor, if you know a good sparky he may be able to test it before you get a new one.
Mar 01, 2009 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washer Won't Rinse (Hotpoint)
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
