Dvd player voice and pictures out of step with each other & I am up a tree as to the cause and solution . Help much appreciated ,Thank you . .... darylodell@yahoo.com ....
  • Anonymous Dec 13, 2008
    don't look like you appreciate any information!
  • 905 Answers
Try a laser lens cleaning disc , and if that don't help then it will need to be manually cleaned
Posted on Dec 10, 2008
Audio Problem with certain DVD's on my Technika RW DVD Player
It may be that the disk is the wrong Region code.
Dec 23, 2011 | Televison & Video
I have a dvd player the soud is working but no picture
Good day!!!
That problem has something to do with the cords/wire (Jack) that connecting the tv and your dvd....My advise is to wiggle the wires if you notice any reaction on the tv contact me....fo more or you can avail my service below for much step by step procedure...thank you...
http://www.fixya.com/marketplace/createservice.aspx?srvid=15697
Nov 13, 2011 | Accurian Televison & Video
Toshiba tv model 2563db has picture until you switch on and off several times then comes without voice but with dvd player there is voice and clear picture.whats is the problem?
Check your amplifier section where you can find the speaker out of your TV board, or replace the amp IC TDA2611A .. or your speaker is bad.
Sep 09, 2011 | Televison & Video
Hi, i have a portable dvd player & the battery is 2 hours. now it only lasts 30 minutes. is there something i csn do to boost it or do i need a new battery. thank you, medina
Your best bet is simply to replace it with a more reliable battery. However, starting the dvd player without a disc so that the settings appear should allow you to change the options on the DVD player. This should allow for the brightness and picture settings to be adjusted to preserve battery to the best of the DVD players ability.
Step One: Remove Disc
Step Two: Turn On DVD Player
Step Three: Enter Settings
Step Four: Adjust the picture and screen settings to maximize the battery life (make the screen less bright for an example)
There may be a setting specifically meant to maximize battery life. Hope This Helps.
May 13, 2011 | TruTech PVS12701 Portable DVD Player
Dvd picture works, vcr picture does not work. Sound works from both. is this a problem with the machine or the set up?
Try a cleaning tape in the VCR. If the pictures both come ut of the same connector then the VCR may be in need of cleaning. Also can you see a picture 'through' the vcr, if you wanted to record on the vcr? Have you tried recording?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 05, 2011 | Toshiba SD-V280 DVD Player/VCR
No sound of voice, only surround sound
If you do not have a center channel speaker connected, then in the reciever setup menu for speakers, there should be a selection for center channel that says something like either yes or no. I'm guessing it says yes. Then you need to select "no" so that the circuitry will direct sound specified for the center channel to be reproduced through your front speakers.
Dec 07, 2009 | Pioneer VSX-D711 Receiver
Kawasaki PVS-10921 sound ok... lines on screen - picture very distorted
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 31, 2017 | kawasaki PVS-10921 Portable DVD Player
Only voice no picuter while playing DVD
make sure the video cable is plugged in correctly, or if it is damaged.
Feb 12, 2008 | Televison & Video
Philips mx3660d
Progressive scan is turned on. Reset the player first, and then follow the instructions in the manual step by step without skipping a single detail - you are flying blind (without picture), so a single omission from the directions will cause this procedure not to work.
Nov 16, 2007 | Philips MX3660D3799 System
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
