Question about Roper RES7646KQ Electric Dryer
Roper / Whirlpool dryer. No power / intermittent power.
I have a Roper RE7646KQ front load dryer. It has worked fine for three years. We recently moved and while I was installing it at the new house It would not power up. No light no heat no motor no buzzer. Nothing completely dead. Then suddenly the light would come on and it would work, but when I pushed it up against the wall it would be dead again. Cord is new and we have power all the way up to the terminal block and to the the timer. I took the top off the dryer and can find no burnt or broken wires or loose connections. The only two things left I can think of is the door switch and the timer. Am I missing something?
  • TV Myers Mar 08, 2007
    Come to find out an animal had chewed partially through the nuetral under the house. When I would pull the unit out it was next to the furnace and grounding out against the frame thus completing the circuit and making the dryer work. So then when I would push it back in it was no longer touching the furnace frame and no longer grounding through the safety ground of the furnace and then not working anymore. Took me a few minutes of pushing it upagainst the furnace and pulling it away but I eventually figured it out!
    Problem Solver:
  • 6 Answers
The door switch would be my top candidate.
Posted on Mar 01, 2007
SOURCE:
Thermal fuse failure
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
I have had my whirlpool front loading dryer for about 5 years. It worked fine for a couple of loads and then when I started to dry the next load, it won't come on. It just beeps, checked the breaker,...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My duet front loader dryer has no power
If you have 220v going to the unit you want to take the bottom pannel off. It should be three tork screwws. Then there is a little white fuse mounted on the blower houseing. This is the most common problem especally if your vent has not been cleaned in a while. (over 3-4 years.)
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Duet Control Locked button cycles on and off
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
If the troubleshoot below does not work, then the problem may be a defective CCU.
The front light lit on my Whirlpool.
Regards.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cleaning lint
Your Roper dryer is made by Whirlpool, there is no reason to clean lint from around the heater, very little lint collects in that area. Every once in a while you can take the front off by removing 2 screws from under the lint screen, then pry up the top and there are 2 screws that hold the front on inside facing out. After removing the front you can vacuum inside below the drum.
Jan 18, 2009 | Roper REX4634KQ Electric Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Roper RES7646KQ Electric Dryer Logo
625 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
