Question about Philips 32PFL5322D Television
Philips 32PFL5322 OIXWL PLUS 2 LCD (TV)
The screen is cracked in the bottom corner and one can just see the image on the top half
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
SOURCE: Top half of screen is darker than bottom half
The problem is most likley the TV backlight - it is very unlikley to be the graphics card or video input or any other circuitry within the TV.
Also, the problem can be manifested by flashing or flickering of one or both halves of the screen, and sometimes it is a left/right split rather than a top/bottom split, depending on where the lights are positioned. Before failure, you sometimes hear a very high frequency buzz for a few weeks before it fails - the frequency can't be heard by most adults as it ranges from 15kHz-25kHz, but children\animals can usually hear it.
Generally you will need to replace the backlight tube or the invertor that drives it. Generally you can identify the backlights as thin glass tubes buried deep within the panel itself usually with one wire going to each end of them - they are very fragile. The invertor is connected to the backlight tube and looks like a circuit board, often containing a high voltage warning. Usually there are two or four conductors connecting the invertor to the tubes, which can be identified as thicker individual wires as opposed to the flat ribbon wire used for data for the actual image displayed on the screen.
On some screens you may be able to unplug\swap one or both tubes to identify if it's the tube or inverter.
Posted on May 03, 2009
mbelectronic
  • 147 Answers
SOURCE: HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Posted on Jul 18, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
Hi everybody, I have a Philips plasma 50PF7321. Two main issues. Sometimes I only get half the screen on ( bottom half). In this case I get a "cut" image and not a "compressed" image, I...
It sounds like you have a problem were the Y sus/buffers board (the one on the left ) has issues with the connectors to the screen need unpluging cleaning and putting back
Apr 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
Only see half the screen - other half blank
Anytime you have a distortion in the image on the screen, this can NOT be reolved with a reset. You have a bad LCD module. Take a look at the pictures on this page and see if one is like the problem you are having.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 03, 2010 | Garmin nuvi 350 GPS Receiver
Cracked LCD Screen
Order by phone 1-888-BESTBUY (237-8289)
Sep 17, 2009 | Televison & Video
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tiny crack in lower right hand corener of the screen can this be fixed or repaired by a professional? IF you have any suggestions or comments fell free to leave them at heathmcguff@ymail.com or call 2
if the crack does not affect picture quality then it's only cosmetic, and you can use Krazy glue or a 5min epoxy to fill it in.
If however the crack does affect picture quality, then you could look into a repair center for repair and get an estimate. If the estimate will be over $100 then you may want to think about buying a new LCD tv.
Most LCD tv's have very small and long lightbulbs at the top and bottom. In the middle back are the electronics....The screen itself is made up of many layers of specialized plastics.
So if you dropped it on a hard surface, and in the future the screen turns dark on you at some point while on, then one or more of the bulbs would've been damaged.
May 23, 2009 | Philips Televison & Video
Philips 32PFL5322D Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
