Question about Samsung RS2630SH Side by Side Refrigerator
Please help fix my fridge
My samsung rl39wbsw freezer is working but the fridge is warm please help as i dont know what to do i have put the settings to make it colder but that hasnt helped.
  • 1 more comment
  • saunby8aw Jan 09, 2009
    samsung side by side refrigerator, digital display refrigerator side flashing and water in bottom of frige and dosent seem cold enough freezer side ok
  • Anonymous Jan 11, 2009
    my firdge is at 18 degree bt freezer is ok any ideas
  • helpless22 Jan 24, 2009
    rs21dcns freezer working fine , fridge at 18 degs.
Mine did that and it was due to a frozen water line that blew out the thermostat. See if the water line is frozen first. It was located on my refrigerator behind the crisper drawers. the tech had me use a hair dryer to thaw out the line
Posted on Dec 23, 2008
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Just noticed that the bottom of samsung RFG238AA
Your settings should be -5 to -10 in freezer and +37 in the fresh food compartment. This will keep the unit from running too long and your floor temp to be normal..
Consult your users manual!
Oct 15, 2017 | Samsung RF265AA Bottom Freezer French Door...
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
My refrigerator is warm and ice build up is happening in the fridge
There is a timer that controls the refrigerator defrost cycles. This is located behind the kick panel at the bottom of the refrigerator. Remove the panel and look for a dial-like device toward the front. Try to manually turn the timer dial and listen for an audible click. No click, no defrost. Call a NEW repairman and have him check the defrost timer. Hope this helps.
Jul 27, 2007 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
427 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
