Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Hard Drive won't accept data
When I try to copy data to the hard drive it says the names are too long or have characters that the disk cannot display and can't be copied. I have had a LaCie before and names were never a problem. Mac font names are sometimes very long and this has caused error messages before. Is there a fix or for this? spotter
    Novelist:
    Champion:
  • 202 Answers
Some LaCie drives ship out formatted FAT32 so they will be ready to use on either a Mac or a PC. If you are getting error -50 when copying to a LaCie drive, or any drive formatted for PC, it is because of the following: Certain characters that can be used in a Mac OS X filename are not allowed in MS-DOS filenames. This can prevent the file from being copied, and can occur when a filename contains non-printing ASCII characters, or any of these characters: ? / \ < > " | > *. Either copy the data off of the drive and use Apple's Disk Utility to erase the drive in Mac OS Extended format, or change the filenames of the documents that cannot be copied. Hope that helps http://www.lacie.com/us/support/index.htm?rid=10033 I also noticed there are some patches for LaCie drives. You may check out the patches before the format. Let me know what happens. Tim
Posted on Mar 15, 2007
Transfer data and operating system from one hard drive to another
Use AOMEI Partition Assistant,a free Windows partition software, to clone data or OS from one hard drive to another. http://www.disk-partition.com/copy-disk-partition-wizard.html
Oct 12, 2012 | Hitachi TravelStar Computers & Internet
I get a big question mark that blinks on and off on my display. I have a Mac Laptop serial # 4H65017MWGL
That means the MacBook can not find a bootable device to startup from.
First thing to do would be try starting up from the CD's that came with the MacBook or the Mac OS CD if you have updated to a newer version of the OS ( 10.5 or 10.6 ).
If the MacBook starts from the CD, good news your computer is still good, just the Hard Drive may have failed or be failing. You can check and see if they Hard Drive is working by going to the Menu on the 1st or 2nd screen when you are booted from the CD and pull down to Disk Utility.
Once you are in Disk Utility if the is more than the CD showing down the left then there is hope, now look and see if the name of your hard drive is listed ( default is Macintosh HD ). If you named Hard Drive shows and you have an external Hard Drive w/ enough free space I would try backing up your drive at this point using Disk Utility to make a disk image on your external hard drive.
Now that you have either backed up your hard drive, already had a current backup or have given up all hope of getting data back, you can either try
  • Just reinstalling the OS on your hard drive ( not my favorite choice, since you might be installing over existing problems and have more in the future ).
  • Erasing the hard drive and installing a clean copy of the OS and re-installing your applications from the original disk and then recovering your data from the backup.
In either case there is the worry that the drive is starting to fail permanently, so now that you have been given a 2nd chance make regular backups or replace the hard drive. ( The hard drive on these is fairly easy to replace and instructions can be found here http://manuals.info.apple.com/en_US/MacBook_13inch_HardDrive_DIY.pdf .
May 12, 2011 | Apple Computers & Internet
HI GOOD EVENING I AM UNABLE TO COPY MY MICROSOFT OUTLOOK 2007 PST FILE TO EXTERNAL HARD DISK. AFTER STARTING COPY FEW MINUTES LATER I FACE THE FOLLOWING PROBLUM CANNOT COPY OUTLOOK:DATA ERROR(CYCLIC...
A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
Try to copy the PST file to another file on your 'C:' drive.
If you do not see the "check", then it is the external disk-drive that has a problem.
If you do see the "check", then open Outlook, create a new folder,
and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
Sep 07, 2010 | Computers & Internet
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
I have a Simple Tech (simple Drive) 320GB external hard drive.the light comes on But my computer won`t recognize it. The light comes on but that`s it.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Jun 12, 2010 | SimpleTech 320GB SimpleDrive External by...
I see only one out of meny dir's in seagate freeagent go ext disk
It sounds disk I/O is creating problem refershing the contents in hard drive.
You can try changing the drive letter on your hard drive, might help.
http://www.wikihow.com/Change-a-Drive-Letter-in-Windows-XP
Also, if any kind of corruption, you can try disk error checking scandisk
http://www.pctechguide.com/tutorials/HDDMaint_Chkdsk.htm
If nothing works, there is other way to see your data in cmd
go to Start->run->type "cmd" and hit enter
To go to your External drive's letter you should know the drive for eg, if your external drive letter is D Drive just type D: in cmd and hit enter. Now you will see he prompt D:\, type dir to list the directories and files in that directory/folder
If you are able to see your files in CMD, you can still back them up
Try following link for more information
http://dosprompt.info/
Jun 02, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
I can't delete files from my 160 GB Simpletech hard drive and it is full, what should I do?
Do a "disk cleanup"
Click on [My Computer]
Right-click on the External drive (D?)
Select [Properties]
In the [General] tab, click on [Disk Cleanup]
It will "scan" your drive, but not remove anything... alow it to complete the scan.
Look at the recommended list that appears and accept its findings.
This should remove non-essential files and leave your data intact.
Burn some of your data, especially video content to DVD (make at least two copies) ... then remove the data from your external hard drive.
You may want to purchase another (larger) external drive. You can use two of them or move your data to the new one.
Sep 30, 2009 | SimpleTech Signature Mini 160GB External...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
154 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
