Question about Pentax Optio S50 Digital Camera
Goes off after lens come out.
By accident camera fell down. after that i have inserted battery inside and pushed the button ON. able to turn on and lens comes out suddenly it gets turned off. lens wont go in and we cannot start it.
if i have take out battery and put it back again it will turn on lens comes out and suddenly it turns off lens got stuck back again.
so, camera is not working at all.
Please help me. its a new camera only one month old.
  • Anonymous Feb 23, 2009
    I have the same problen but lens goes in and camera shut down
Just turn off the Camera. then shake it hardly in your hand. then turn on the camera and check the operation.
Posted on Mar 26, 2009
    Novelist:
  • 103 Answers
Get it repaired under warranty. Sounds like a logic circuit problem.
Posted on Jan 05, 2009
Turns on, lens goes out then cuts out
Do a power reset on your camera. Switch on your cam. Now, without shutting it off, just open the battery compartment and take the batteries out.Check if there is a small pinhole in the compartment, which is usually a reset button. If it's there, insert a pin inside it and press a little, u will feel a button has been pressed. DO NOT PUSH Forcibly. Now, wait for about 1-2 mins. and then put the batteries in and turn on the camera. Try it. (P.S. Before doing this, Please check the batteries if they are charged or not, if not, charge them first.)
Sep 16, 2013 | Fuji FinePix S7000 Digital Camera
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
    According to ehow:
    Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • May 11, 2011 | Cameras
    My camera lense is stuck it won't go back in the camera. also it has a blurry picture so i can't see through it. everytime i turn it off it makes a beep noise. the problem that caused it was that it fell...
    Fixing a Lens Error on a Digital Camera
    This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
    Nov 26, 2010 | Samsung SL102 Digital Camera
    When switching my camera on it just switches itself straight back off?
    Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
    With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
    Please let me know how this goes. Thank you for using FixYa.
    Nov 06, 2010 | Kodak Easyshare V1233 12.1MP Digital...
    Lens Error!
    In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
    Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
    My digital Sony camera fell down Lens got stuck
    if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
    .... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
    also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    if that doest help
    Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
    if that doesnt help
    Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    regards
    iversh
    Jan 08, 2009 | Kodak EasyShare M863 Digital Camera
    Lens error - stuck half open
    just check the power of battery ........ if it is ok just remove the battery .........clean the battery contacts properly and once again insert the battery ............then power on this will remove your problem
    Jul 23, 2008 | Nikon COOLPIX L3 Digital Camera
    Buzzing sound, wont come on!
    Don't try and manually push in the lens at first...the buzzing is a warning letting you know that something is wrong with the camera. By accidently removing the batteries during shut down you interupted the shut down sequence. Try and turn on the camera and immediately press the play button on the back. This should reset the camera. If not and if you are under warranty it needs to be serviced. If you are not under warranty then you can try and push the lens down. Don't use a lot of force but try and gently do it.
    Jun 09, 2008 | Cameras
    Camera fell off TV tray; lens bent and won't retract
    i had the same problem. just force the lens back into place. I did that and it worked perfectly!
    May 15, 2008 | HP Photosmart R927 Digital Camera
    Pentax Optio S50 Digital Camera Logo
    196 people viewed this question
    Top Pentax Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Pentax Camera Expert? Answer questions, earn points and help others
