Question about HP Office Equipment & Supplies
HP Laserjet 1600 won't retain paper settings
Hi I'm trying to print on light card, but when I go into Properties from the print dialogue and change the paper type to cardstock, click Ok, and then go back in to check before printing, it's defaulted to 'plain' and the printer tries to print it as papaer - result, smears, lines, blothes on the card. Plain paper version is fine. Can you help please?
  • 1 more comment
  • geoff647 Dec 11, 2008
    not sure whether I am or not - how do you change settings in administrator mode
    Hi
    on right clicking I don't have the 'run as admin' option, and can't find 'devices' in any of the options on offer.
    Ah, it appears to have accepted that. Thank you very much. Will I need to go that route to change it back to normal paper printing or will it accept it from the print dialogue screen do you think?
    Scholar:
  • 81 Answers
Hi!
Welcome to Fixya,
if your using XP or Vista
  • click the start, in menu click the printers and faxes icon to display all the printer.
  • and then, right click the printer your using, in the drop down menu select properties.
  • in printer properties window, click device settings.
  • set the paper sizes.
  • and then click apply and ok to exit.
  • right click again the printer your using and then, in the drop down menu select printing preferences
  • in the printing preferences window, at layout window click advance buttons
  • and then, set the paper size and all the setting to fit your needs.
  • in paper/Quality windows set the paper source to manual feed
  • and then in media select the paper you're using.
  • and click apply and ok to exit.
If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
aclamonte
Posted on Dec 11, 2008
  • 53 Answers
Right click on the printer from the printer control panel, and select printing preferences.
Configure your printer printing defaults, and click OK.
Now try a print again.
  • 495 Answers
Could you tell me if your are changing this settings in administrator mode. If settings are not retained, that means printer servidce is not running in admin mode.
  • 1 more comment
  • Manoj Rout
    Manoj Rout Dec 11, 2008
    • Click the start button, in menu click the printers and faxes icon.
    • and then, right click the printer your using, in the drop down menu select "Run as admin" option to select properties.
  • Manoj Rout
    Right click on the printer and select printing preferences.
    Configure your printer printing defaults, and click Ok.
  • Manoj Rout
    No problem buddy.. it will accept from print dialog screen itself. If any problems, do contact me.. Thanks for using Fixya..:)
Orange blinking light hp laserjet 1600
this signal issue mean any paper jam or toner cartridge end remaining or end of drum, transfer belt life
Jul 12, 2014 | HP LaserJet 1600 Printer
Can't get the duplexor to print on both sides . The duplexor is installed, but it will not allow me to print on both sides of the paper. It will print one side then it flips to the other side and says...
Unless the driver has an 'auto-discovery' feature (not all drivers do), you would need to configure the driver to show the duplex unit as 'installed'.
On the driver Properties dialogue, select the "Device Settings" tab (may only be available when logged in with administrative rights) and change the 'duplex unit' option from "Not installed" to "Installed".
hope this works for you ,all the best.........
Mar 13, 2010 | HP LaserJet 4250n Printer
Can not set my hp laserjet 3015 to print postcard stock..
Follow these steps to print on cards: NOTE: Make sure you have the cards loaded in the input tray.
  1. On the File menu in the software program, click Print .
  2. Select the HP All-in-One as the printer.
  3. Open the Properties window. Depending on the program, the button might be called Properties , Options , PrinterSetup , or Printer .
  4. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs. NOTE: Select the appropriate options for the print job by selecting one of the predefined print tasks on the Printing Shortcuts tab. Click the appropriate type of print task in the What do you want to do? list. The default settings for that type of print task are set as summarized on the Printing Shortcuts tab. If necessary, adjust the settings here, or make changes on the other tabs in the Properties window.
  5. Click OK to close the Properties window.
  6. Click Print or OK to begin printing.
Jun 17, 2009 | HP LaserJet 3015 All-In-One Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Page alignment
Hi rene_schuste: This info may help you with your problem.
If you used an older or different HP LaserJet printer driver (printer software) to create the document,
or if the printer Properties settings in the software are different, the page format might change when
you try to print using your new printer driver or settings. To help eliminate this problem, try the
following remedies:
● Create documents and print them using the same printer driver (printer software) and printer
Properties settings regardless of which HP LaserJet printer you use to print them.
● Change the resolution, paper size, font settings, and other settings.
Graphics quality
The graphics settings might be unsuitable for your print job. Check the graphic settings, such as
resolution, in the printer Properties and adjust them as necessary.
Apr 08, 2009 | Office Equipment & Supplies
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Printing on card
160gm is too thick for the printer. Printing a couple of sheets should be okay, but more than that and you will damage the cartridges hence the "grey" haze. Check your printer specs -- max. gm on these printers is probably 105gsm.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Out of paper light
I've been stuck with a flashing red paper light for a while. The printer could print from the manual tray and could also print test or diagnostic pages.
So I thought it might be driver related, and indeed it was.
There's a nasty setting in the printer properties that makes the printer go woo-hoo. So go to printer properties > tray settings. Check the "paper size" of "Tray 1". If it's set to "undefined", change it to your corresponding paper format. Click Update, Apply. Now print happily.
I still wonder why that setting magically changed. Hope this helps someone.
Aug 29, 2006 | Brother HL-2040 Laser Printer
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
