My hp wireless assistance does not open any longer. it formerly used to work. any attempt to on it fails
  • 76 Answers
Go to www.hp.com and get a fresh copy of that assistant..not a robust app..and keep it handy, you'll need it again, no doubt
Posted on Dec 10, 2008
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
My wireless connection failed. i connect to the
reinstall the drivers for your card after completely uninstalling them
Dec 02, 2009 | Gateway MX3414 Notebook
Wlan stopped working on hp pavilion. It is no longer in the device manager and the wireless assistant will not open at all.
This would normally mean that your wireless card has been turned off or uninstalled, since you did not uninstall it, it was turned off from the external button or switch, check around the outside of the laptop, and the top part above the keyboard for it.
Oct 27, 2009 | HP Pavilion dv9000z Notebook
My hp wireless assistant is not working!
HP wireless assistant is a factory Shipped software. Try uninstalling it from Add/remore Programs ( Start > Run > Appwiz.cpl) and uninstall. Install it from Pc Help and Tools/Pc Tools under All Programs of Start menu using the Application recovery option. If No recovery partition, install from Hp.com using the Product Number of the Laptop
Regards
Nick
Oct 11, 2009 | Computers & Internet
Presario f730us wireless light stays red and in device manger has nothing about wireless
This is a flaw with Nforce chipset and Broadcom wireless cards. But getting HP to admit to it is another story. Every F700 used on a daily basis will have their wireless fail. Here are the solutions to try and resolve this...
1. Buy and install new wireless card ( has worked for me numerous times. Cheapest solution, $25 BUT may not work)
2. Buy a USB wireless adapter (little bit more money but will definitely get you up and running $50)
3. Replace motherboard (refabed cost around $120 or so. There is a reason so many of these go bad... Thank you hp!)
Other than that don't believe it s software/virus problem as it is a pure bad hardware issue. I am still a fan of Compaq laptops.. Just have to ignore this little bubmle on some engineers work station :)
Aug 29, 2009 | HP Compaq Presario F730US Notebook
My hp wireless assistance does not open any longer. it formerly used to work. any attempt to on it fails My BIOS does not regognize the wireless
Does it show up in the Device Manager? Does it say it is working correctly? If it says it doesn't have a driver, the manufacture's website should have it. Although not showing up in the BIOS if it used too doesn't sound good. Try reseating the WiFi card again. If that doesn't work, it sounds like it is dead.
Jan 15, 2009 | HP Pavilion dv6000z Notebook
Internal Wireless adapter failed
Your wireless zero configuration being manipulated by the add-on service of manufacturer software. first you can manually turn in the Wireless Zero Configuration by typing services.msc on run menu. After you run the services you will see Wireless Zero configuration please enable and start it with the given option.
Next you can open the Wireless Network Connection option, uncheck the add on protocols, such as AEGIS and WLAN protocol. after restart computer should work with wireless without problem.
Please post if you need further assistance.
Good Luck
Jul 21, 2008 | HP Pavilion dv1000 Notebook
Hp wireless assistant 3.00 C2
No problem, I am here to help you out. First here is the adress to download the HP Wireless assistant: http://hp-wireless-assistant.software.informer.com/
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
iF YOU NEED FURTHER CLARIFICATION JUST FEEL FREE TO CONTACT ME, THAT WHY WE ARE HERE FOR.
Jun 17, 2008 | Compaq Presario 5000 PC Desktop
Wireless connection no longer works after vista upgrade
HP uses "branded" wireless modules,which means it's got to be HP or it doesn't get to play.
Does device manager see the wireless device? I've had similar situations with the 8000s. Always the driver or the wireless utility was the problem. Try letting windows manage the device, or if you already are, disable that and use the devices utiliy to manage it.
BTW, most systems consider BT as wireless.
Good luck, hope that helps
Nov 25, 2007 | HP Pavilion zd8000 Notebook
Microsoft wireless comfort keyboard
i havesame problem ivetried to update drivers but its not working
Nov 03, 2007 | Microsoft Wireless Optical Desktop Comfort...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
