We have problems opening the door sometimes.
The door opening button wont always work. how do we fix this issue?
  • 1 more comment
  • andrew_gilbe Dec 10, 2008
    It is an Asko w6021 quatrro
    Thanks very much for your advice - it turned out that there was the casing from one side of a Swiss Army Knife caught in the filter! I removed this artifact with a screwdriver and then put the filter back in and went through the drain cycle which took about a minute then the door opened! Fantastic advice - thank you very much. Have a great Xmas and thnks again. Cheers, Andrew.
  • Barry Coates
    Barry Coates May 11, 2010
    Make and model of washer plz.
  • Washing Mach... Master
  • 3,463 Answers
Make sure there is no water left in m/c otherwise this prevents the door opening.
If ther is a filter, remove and clean.
If you still have trouble opening door ,then do the following.
On the lower left corner at the front of the m/c, you should see a red tab there, pull on this and door should open.
This should solve your problem.
Plz leave feedback.
Posted on Dec 10, 2008
My garage door always stops wnen closing.sometimes it wont open.and sometimes it looks like it has no power at all and will do nothing when i press the control
Jojo, possible motor or control board issue, may have to get a garage door tech. to have a look. Befor you do check the trouble shooting links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Opener Repair How to Troubleshoot Openers
Garage Door Opener Troubleshooting step by step
Garage Door Opener Repair Help Troubleshooting Sears PartsDirect
Home Repair Remodeling How to Troubleshoot Garage Door Openers
Jul 02, 2016 | Craftsman Garage Door Opener 1/2 HP Chain...
My stanley mod6500 1/2 hp lightmaker sometimes opens and when open to set distanve it kicks out to "reset mode" ( have to switch manually from operate to vacation then back to operate ) to reset and then...
You could have a problem with the door which is causing the opener to kick into a safety mode. Release the door from the opener, run it by hand several times. If you feel it bind, figure out where it's binding and resolve that issue. Then reset your opener again and it should be fixed. If it is not binding, then most likely you have a board problem and will either need to replace the board or replace the opener. Stanley's are known for these type of board issues. I would stick to a liftmaster if you replace it.
Feb 20, 2015 | Building Materials
I have an akira washing machine. problem is that when it comes to spin...E2 will appear. what is the problem n how to fix it? thank you.
E2 is a faulty button on your control board. Rub your hands over the buttons to make sure none of them are stuck and if you find nothing, try to unplug the unit for 60 seconds. If you continue to have issues, the control board will just need to be ordered and replaced to fix the issue. Here is also a link for the manual. Akira Service manual Home Appliance Washing Machine Always get a quote for motherboards as they vary alot in price and can sometimes be more then what the machine is worth.
Mar 16, 2014 | Washing Machines
2000 vw passat door latch
Sounds like something came loose on inside of door. People who lock there keys in thier car always try to unlock the doors with coat hangers and all kinds of stuff. Sometimes it knocks the clips loose inside the door and causes handle to not open door. Sometime they just wear out. I believe your going to have to take the inside door panel off to fix it..
Aug 18, 2013 | Cars & Trucks
Fuel door on a 2011 kia sorento has always been a little sticky, but now it wont open at all. Repeatedly pusing the button and it clicks at the fuel tank, but the lid doesnt oopen. just about out of gass...
Question is whether the cable/unlatch device is operating, or if the spring that pushes the fuel door open is out-of-position or broken. Have someone else operate the button while you have a fingernail or non-scratching inplement ready to gently pry the door open. If the door does not open, there may be a problem with the cable/unlatch device. If you can get the door to open by hand when the button is operated, you may have a broken or displaced sping, which will be apparent once the door is open. I fixed this issue on our '92 Sidekick by installing a small spring from an old flashlight, set up so as to push gently on the door near the hinge point, while wrapped around the original support bracket. Best luck!
Jan 12, 2011 | Kia Sorento Cars & Trucks
Citroen C5 2004. rear doors dont always open. Sometimes one will and one wont, sometimes neither will open and sometimes both will work fine.
Hi! Its definitely the door actuators. The door actuators may be faulty thats why it fails to open at times. Once the actuators are replaced you'll be good. Hope this helps and have a good one!
Aug 17, 2010 | 2005 Peugeot 405
Door always opens, intermittant stopping when the door is closing. Sometimes it closes all the way, other times it stops repeatedly and you must press the close button many times to get the door to close....
Sorry to say,u should of replaced the whole control box.This is not a sensors problems,it the control box problems.U know basic electronic's and soldering?Take the control box aparts,check for these bad capacitors leakages,these capacitors alway have the top of it bulges or puff up.These capacitors not giving it max power that why it work sometimes,sometimes don't.Replaced these leakage capacitors,ur power should return yo normal.
May 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My gas cap and trunk wont open. I need gas. Te button on the console won't release the gas cap to open or the trunk. Audi TT 2002.
Take your key and go to the drivers door, make sure the door is unlocked by pulling on the handle, open and close the door. Insert the key and "lock" the door, double check that it is locked by pulling on the handle. Insert the key and "un-lock" the door, use the handle to open the door and now press the fuel door key and it should open, same for trunk release button.
Audi's are a strange breed, sometimes you just need to "re-set" some stuff. But in the future if you lock the car with the key, the fob will unlock the car but the three buttons in the console will not work, the fob will function correctly.
I hope this helps.
Feb 27, 2010 | 2002 Audi TT
Ok i have a question. I have a 05' Cobalt LS and sometimes its like the door locks get jammed or something. Sometimes the unlock button wont fully unlock it the unlock thing will pop up but door wont open!...
sounds like you need to replaced the latch in the door. or like my 06 cobalt lt the door was bouncing and not closing all the way, or not opening. they cleaned my latch and i havent had a problem since, but that latch in the door could be your problem.
Apr 16, 2009 | 2005 Chevrolet Cobalt
Garage door only works partly
some thing blocking sensor or laser is not in proper alinement
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
