Question about SAMTRON 55V 15" CRT Monitor
Horizontal width problem
My monitor width is redused sudenly ,while i manuly adjested through front panel but it increased up to 80%,picture normal,i checked the SMPS volatges averithing normal ,what may be the proble .model samtron 56v
    New Friend:
Plese check 2sd 2058 transistor mounted on heatsink of h/o transistor
Posted on Feb 25, 2013
    New Friend:
  • 62 Answers
1. change the flyback 1600v working voltage pf.(near to Horizontel transistor.)
Posted on Dec 10, 2008
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
CRT Monitor width problem
replace flyback and yoke<br /><br />
Jan 15, 2010 | LG Studioworks 700S 17" CRT Monitor
563A horizontal too wide unable to adjust, how to fix?
I HAVE LG CB563G MODAL15'' MONITOR HORIZOLY EXEED SCREEN I CANOT ADJEST WHEN ON MONITOR 1.1/2 HOUR IN
H/S C5803 TRASITOR FILES PLEASE HALP
Jan 15, 2010 | LG Studioworks 563N 15" CRT Monitor
Width problem , front panel all switch working properly , but picture cut off 1'' inch bothside from horizontaly. please detaily explane.
HORIZONTAL WIDTH PROBLEMS COME FROM COMPONENT FAILURE OR BAD CONNECTIONS IN THE DEFLECTION CIRCUIT. FIRST CHECK THE POWER B+ SOURCE AND MAKE SURE IT IS UP TO NORMAL, SHOULD BE 130VOLTS THEN RESOLDER THE DEFLECTION CIRCUIT, YOKE RETURN CAPS AND DRIVER CIRCUIT. IF NOT SOLVED THE CAP IS BAD OR A SHORTED COIL IN THE RETURN CIRCUIT.
Dec 26, 2009 | Televison & Video
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Screen width unadjustable
chk the resolution is as mentioned by the makers in the user mannul.
Jun 16, 2008 | Computers & Internet
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
Width of picture increase
Have you checked your display adapter settings? Check the display settings in control panel. Make sure you are viewing the screen at a decent resolution. 800/600 or larger. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | LG Studioworks 563N 15" CRT Monitor
Width problem
To have unlock your control (auto-adjust ...) you have to hold down the "menu Key" for about an 10 seconds. This will unlock your monitor! peroludiarom@abv.bg
May 30, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
240 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
