Question about Indesit W 123 Front Load Washer
Indesit 1200 series wont work.
The front where the programme lights up keeps flashing F-03 and i cant get it to stop flashing. I have tried switching on and off but still keeps flashing??????????? Help please.............
  • Indesit Master
  • 3,463 Answers
F03 indicates that the wash thermistor is open or short circuit, the thermistor is part of the heater element. you need to test the heater and thermistor, and possibly replace.
Indesit recommend that you call an engineer, but it can be done by some one who is competent enough.
Unplug before you do anything to it.
Plz leave feedback.
Thanks
Posted on Dec 10, 2008
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
293 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
