Question about Uniden Cordless Phone
Uniden7488 base unit and handset doesn't registrar
I done as per procedure in the handbook. But it indicates out of range.
Pl tell How to registar the handset and base unit
Thank you
  • oerke Dec 10, 2008
    I have done everything the manual said and a few solutions of my own. Nothing seems to work. Out of range still appears on my handsets.
  • 35 Answers
PRESS END AND POUND UNTIL YOU SEE SYSTEM REST THEN SCROLL DOWN TO REPALCING BASE THE SELECT YES THEN PRESS MENU ON THE BASE AND GO DOWN TO REGISTER HANDSET, THEN PRESS THE POUND KEY ON THE HANDSET.
Posted on Sep 07, 2009
PLS REG H/S on screen
Consult the owner's manual on how to register a handset with the base unit.
It usually means that you press a combination of buttons (see the handbook) until the phone stops display a message like "Range Out" or "Searching".
You may also need to name the handset so you know where it needs to be returned, like "living room", "kitchen", etc.
May 24, 2015 | Cell Phones
Hi, suddenly I loss my connection of telephone KX-TG 5632to the base from the handy , I need the way to register it from the base, thanks for your cooperation
1 Handset: {MENU} i {0}{0} 2 Base unit: Press and hold {LOCATOR/ INTERCOM} until the CHARGE indicator flashes. L After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until the handset beeps.
Jun 12, 2011 | Panasonic KX-TG5632 Phone
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
3 Handset:
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
How can i set up speed dial?
Registration Register the handset to a KX-TG6700/KXTG6702 base unit. 1 Base unit: Press and hold {INTERCOM} until the IN USE indicator flashes. L After the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 2 Handset: Press {OK}, then wait until a beep sounds.
http://adcombhs.com/shopsite_sc/store/html/Panasonic_KXTGA670.pdf
Mar 07, 2011 | Panasonic KX-TGA101S Cordless Handset
Phone displays a message saying no link to base when it is closer to the base?
Following may be the cause for getting no link to the base.
1. The handset has lost communication with the base unit.Move closer to the base unit, and try again.
2. Confirm that the base unit’s AC adaptor is plugged in.
3. Raise the base unit antenna.
4The handset’s registration may have been cancelled .Re-register the handset.
To Register, follow the below steps.
Headset: Press MENU and then press ‘0’ ‘0’
Base unit: Press and hold HANDSET LOCATOR until the CHARGE indicator flashes.
(After the CHARGE indicator starts flashing, the rest of the procedure
must be completed within 1 minute.)
Handset: Press OK, and then wait until the handset beeps.
Your handset is registered to Base unit.
Thank You
Aug 18, 2010 | Panasonic KX-TG2620 Cordless Phone
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
indicator flashes.
LAfter the IN USE indicator starts
minute.
3 Handset:
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Uniden Cordless Phone Logo
51 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
