My project name is digital image processing.so want basics to do this project.
  • 53 Answers
Start of by looking at the different types of image file formats as the inputs, for example JPEG, GIF, BMP, TIFF, PNG etc. There are loads of them with different pro's and con's for each.
Also take a look at the vector based file formats, and how vector images are scaleable upwards to any size, without loss in resolution.
I'm not sure about the details of your project, but it falls into the 3 main topics of :-
  1. Inputs to the system
  2. How it is processed
  3. What the final output is
Posted on Dec 10, 2008
How can I Fix Google Chrome Error 0xa0430721 ?
Try this:
Step1: Open your Application Data Folder.
For Windows XP: %USERPROFILE%\Application Data\Local
For Windows Vista/7: %USERPROFILE%\AppData\Local
Step2: Delete Google Folder (If you have other Google Applications, open the folder and delete "Chrome").
Step3: Open Task Manager>Processes (If running on Windows Vista/7, select "Show Processes From All Users" and click "Allow")
Click on "Description" (on top where you see Image Name, User Name etc..)
Scroll Down until you see anything with the Description "Google".
End each process 1 by 1.
Click on "Image Name" (on top where you see Image Name, User Name etc..)
Scroll Down until you see anything with the Image Name "Google"
Step 4: Go to http://www.google.com/chrome/
and install Google Chrome.
Nov 13, 2017 | Google Computers & Internet
How I can produce stunning pictures?
Now a day's everyone has a digital camera or smartphone and spends time uploading images to their system or the Internet.Once you have the Photoshop editing software then you have everything that you need to remove the original background from the photo and add in digital backdrops.
Elite backdrops
Sep 05, 2014 | Computers & Internet
A list and defintion of the file types raw b, raw, fine, norm and basic
The D3000 can store still images in two different formats. JPEG is a standard format, recognized by just about every image viewer and image manipulation program in the world. RAW is actually NEF (Nikon Electronic Format), a Nikon-proprietary format which incorporates almost all of the data captured by the sensor, without the processing of JPEG. JPEG files have the color balance, sharpening, contrast, and all the other camera settings done on the picture. With RAW files, you can change any or all of them and produce new JPEGs. In this respect the RAW file is similar to the original negative you get from processed film, while the JPEG file is like the final print. RAW files need special software for viewing and editing.
All JPEG files are compressed to save space. FINE, NORM, and BASIC represent different levels of compression. FINE does the least compression and takes up the most space, BASIC does the most compression and takes up the least space. Compression always loses some quality, so in general the less the compression the better the quality.
RAW+B simply stores each of your pictures as a RAW file and a BASIC JPEG file.
Having said all that, you should use only RAW or FINE settings. You didn't buy a SLR only to throw away picture quality, did you?
Oct 25, 2010 | Nikon D3000 Digital Camera
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
When ever i start my pc windll32.exe error comr how i solve it?
use windows task manager to delete kill this error---
To open the Windows Task Manager, use the combination of ctrl+alt+del or ctrl+shift+esc
Click on the "image name" button to search for " windll32.exe" process by name.
Select the " windll32.exe" process and click on the " end process" button to kill it.
Oct 31, 2009 | Microsoft Windows Vista Home Basic Edition...
I have a runtime error 9 subscript out of range, when i try to open a program
  1. Start the Visual Basic Editor (press ALT+F11).
  2. If Project Explorer is not visible, press CTRL+R to activate Project Explorer.
  3. Click to select the Visual Basic project that contains the module sheet that you want to copy.
  4. On the Tools menu, click References. Click to select the Microsoft Visual Basic for Applications Extensibility 5.3 check box, and then click OK.
  5. Click Module on the Insert menu.
  6. Type the following code into the module sheet: Sub CopyModule() Dim CodeLines As String Dim ModuleToCopy As VBComponent Dim NewModule As VBComponent ' Set a variable to the module to copy. ' Note: This assumes that the name of the module to copy is ' "module2". Replace "Module2" with the name of the module to copy. Set ModuleToCopy = _ Application.VBE.ActiveVBProject.VBComponents("module2") ' Get the Visual Basic code from the module. CodeLines = ModuleToCopy.CodeModule.Lines _ (1, ModuleToCopy.CodeModule.CountOfLines) ' Create a module sheet in another workbook. ' Note: You must refer to the name of the Visual Basic project. By ' default, the name of all new projects is "VBAProject". You may want ' to rename the project to which you are copying the contents of the ' module sheet. Set NewModule = Application.VBE.VBProjects("VBAProject") _ .VBComponents.Add(vbext_ct_StdModule) ' Add the Visual Basic code to the new module. NewModule.CodeModule.AddFromString CodeLines ' Rename the new module to the name of the previous module. NewModule.Name = ModuleToCopy.Name End Sub
  7. Run the CopyModule procedure.
Regards
Samson Ved
Dec 05, 2008 | Computers & Internet
Map loading problem posted on 1 May
Hi again,
To my knowledge, am afraid it is not possible. A *.tif image is very basic graphic file whereas an *.sis is a simulated 3D image.
Perhaps you can try doing a Google for "convert *.tif to *.sis".
Good luck with your project.
May 02, 2008 | Cell Phones
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
