Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
I changed my password on my router to a very large password (168 characters). It accepted it. But when I went back in to test whether I could change it again, it would not let me in. It said it couldn't validate the user. I didn't want to reset the router and loose my config data. Is that what I have to do? What is the maximum character length for the router anyway? Thanks.
    Problem Solver:
IF you don't know the password, can't duplicate it, your only option is to do a reset, at least you can get it back to square one.
Posted on Dec 10, 2008
Don't remember my password on D-Link WBR2310 wirless router
I would reset the router and start over. There is a pin hole on the unit that you press in and hold for 30 seconds. That should reset everything on the router. Depending on the encryption that you use, yes there is a certain number of characters required. You should use at least 8.
Oct 23, 2017 | D-Link RangeBooster WBR2310 108Mbps 80211g...
Http 192 168 15 1
Reset the router by pressing the reset button for 30 sec, after doing unplug every cable plugged with it.
now connect it back to power and modem, and connect to a computer using LAN cable.
now check for the ip address of router, just take the user interface page of router by typing 192.168.1.1 in IE. from security option, you can change the password.
Aug 23, 2013 | Linksys WRT54G2 Wireless Router
Changed password now can"t access router
Your laptop still insists on using the old password that's why it can't connect. Go to Control Panel > Network and Internet > Network and Sharing Center > Manage Wireless Networks. Select your router's SSID. Right click on it and change Properties > Security > Show characters. The old password that you forgot should appear. You may then change it to the latest one.
You may also click on the wifi signal icon on the lower right corner of your Taskbar, right click on the router's SSID, select Properties > Security > Show characters to reveal the old password you forgot and change it to the latest one.
Jan 03, 2013 | Belkin Basic Wireless Router
Default admin password
  1. Enter your user name. If you didn't change the user name during installation, enter admin in theUser Name field. [Show Me]
  2. Enter the password you entered during installation and click OK. Additional characters will appear to be inserted as you enter your password. This is designed to hide the number of characters in your password.
    • Note: If you didn't change the default password when you set up your router, it may have been changed to your router's serial number to provide greater security. You can find your router's serial number on a label affixed to the bottom or back of your router.
    • Note: If you can't remember your user name or password, you must reset your Verizon MI424WR router to the default settings and reconfigure your home network.
Feb 23, 2012 | Actiontec GT704WG Wireless Router...
My new netbook won't accept my seven letter password on my linksys-G Home router. It's asking for 9 letter password which i don't have. please help
A linksys router password should contain at least 8 different characters. You have to put one or more character to change or put your password as authentication. If you have a further query then let me know. Thanks for using FixYa.
Sep 11, 2011 | Linksys Wireless-G Broadband Router
Chige pas wrd
To change the password:
1 Click Password in the left column. The Password screen opens.
2 In the New Password field, type the new password (up to 9 alphanumeric
characters).
3 In the Verify Password field, type the same password to confirm your
change.
4 Click Save to accept your Password change or Cancel to remove your entry
and return to the default setting.
Hope this helps and thanks for using FixYa!
Dec 04, 2010 | Gateway Wireless-B Router (wbr-100)
How do I enable wpa encryption? I have an
To set up the correct security protocols for your router:
1 Click Control Panel > Device Security.
2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
characters as well as numbers. It cannot be longer than 64 bytes.
3 In the Login Password field, enter your Login Password. Create a password that
contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
4 Re-enter your Password.
5 Click Apply.
6 Once the settings have been accepted, click Restart and log back into the
Configuration Utility using your new User ID and Password.
7 Select Wireless > Basic.
8 Change the SSID to a user-friendly name and click Apply.
9 Navigate to Wireless > Security.
10 Select WPA-PSK from the ESS Authentication options.
11 Select TKIP from Encryption Status options.
12 Click Apply and then click Restart. Your wireless security configuration is now
complete.
Mar 26, 2009 | Arris WR850G Router (DHWR850G)
Wifi
There is a possibility that the user name and password that you are using is not used for the wireless connection of the network. If you have WPA enabled on your router, you need a password with a minimum number of 8 characters. If you enabled WEP on the router, it may need 10 or 26 characters depending on what type of encryption is enabled on the router.
You can check that using the Web interface of the router. Try these steps:
1. Connect a computer to the router wired then restart the computer.
2. Launch an internet browser and type in http://192.168.0.1 or if you changed the IP, use the changed address.
3. If it asks for a user name and password, set admin as the user name and password as the router password. If you have changed the password, use the new password.
4. Click on the wireless and check the security type. Make sure that the Mac filter is disabled and there you can find the network key set on your computer.
5. You can then use that key to connect your wireless computer
Jul 30, 2008 | NetGear DG834G Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
