Question about HP LaserJet 3390 Printer
HP Laserjet 3390 printer right side hinge broken Need to check the availability of ADF assembly hinge kit wether readily available or else the top panel i.e the ADF assembly is available in the market
  • freddie007 Jan 13, 2009
    My problem is with our HP Lasejet 3390. The feeder is mispicking. Is there anything I can do before I send it in for repairs. The repairs will teke 3 days and it will cause down time in my business.
  • 859 Answers
Sure, they are available. Take note there are two part numbers for your printer. You should see this on the back of the printer but it should not make a difference in your particular part need.
The exploded diagram for the ADF is here. You can click on an illustrated part to see its price. This seems very affordable to me on my inspection.
This is the page to start from when selecting a part. What I found is that the Keyword and Category search did not produce results. I clicked on the Select A Diagram link and the selected the product for the ADF in the Category drop down list. This results in a parts explosion where each part shown is a clickable link to a part listing including price.
You should be able to select and purchase from there.
The ADF Top Cover was only $14. That seems pretty fair but I suggest you look at the part explosions and you will know more of which part you need and want exactly.
Thanks for using FixYa,
Posted on Dec 10, 2008
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Why does it make a grinding noise while printing?
If you have an older LaserJet, overhaul parts/kits may not be available. You may have to check on the HP website to determine availability/
Mar 07, 2013 | HP LaserJet M5025 MFP Printer
The roller in the feeder has come out, I don't know how to put it back in
I am not sure as to which roller you are talking about but please find below the solution. !!!!DO RATE MY SOLUTION!!!Pickup roller replacement
  1. Tip the device over on its rear side, with the top of the device facing you.
  2. Rotate the bushings (callout 1) on each side of the roller upward. c02755446.gif
  3. Remove the left-side bushing by sliding the bushing to the left.
  4. Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then lift the right end of the shaft.
  5. Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device. c02755447.gif -------------------------------------------------------------------------------------------------------------- This is for ADF (Automatic Document Feeder) on top of the printer.
    3. Press the round blue button while lifting the green lever. Rotate the green lever until it stops in the open position. The pickup roller assembly should remain on the surface.c00802892.gif
    4. Remove the assembly, and then wipe the assembly with a soft, dry, lint-free cloth.c00802893.gif
    5. Replace the assembly, with the largest roller down, in the upright holder, and then press until the assembly snaps into place.c00802894.gif
    6. Make sure that both sides of the assembly are secured by the blue hooks.c00802895.gif
    7. Lower the roller assembly, and then close the ADF cover.c00802896.gif NOTE: If jams continue in the ADF, contact a local HP-authorized service provider.
Jun 27, 2011 | HP LaserJet M3027x MFP Printer
HP M3035 ADF has two black plastic pieces that interact with the roller gear assembly. One black piece has a cutout that fits around the blue button that you press to release the roller gear assembly and...
Unfortunately for this model the ADF section isn't broken down into it's individual components,
the part numbers available for the ADF are as follows: (direct from the Service Manual)
Control Panel
Cover, ADF
ADF feed roller kit
Input tray, ADF
ADF assembly
Scanner assembly (ADF assembly is not included)
However your best bet would be to call around to all of your local printer repair shops in your area and asking them if they have any of these M3035's sitting around for spare parts.
Otherwise I could try to find a good picture of the ADF Feed roller kit and see if it contains the parts you're looking for.
Hope this helps! If so please don't forget to leave a positive review for me. :)
Jun 07, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
Printer not picking the paper and a red light is on
HP Laserjet printer top door hinges are broken. Is there parts available and if you do then I need instruction how to. Thank you
Apr 06, 2011 | HP LaserJet 4L Printer
I have a HP 3390. When I make a copy form the ADF it has a vertical line down the copy. All is OK when I make a copy form the glass or receive a fax.
you need to clean the rollers of adf and the glass strip that you will find when you open the adf cover.
and then try to copy
Oct 21, 2009 | HP LaserJet 3390 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
HP 2600 Cartridge Jam on Right Side
If they are locked in on the right side, the cartridge drive(s) are not being retracted when the front door is opened. There will be a broken part, which is difficut to obtain, and requires a major stripdown of the printer to find and repalace.
It can be easier and MUCH quicker to replace the whole gear assembly on the right hand side of the printer. These ARE available, and can also be removed from another printer with other faults/damage which renders that one BER.
Jun 17, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet M3035xs ADF Assembly?
The blue plastic piece is the clip that holds it all together. Facing the front of the printer. Open the top cover of the ADF. Flip the assembly with the green and blue plastic to the left. Hold the the squarish looking plastic frame in your hand so that you can see the black gears, with those to the back of the printer and the shiny silver shaft with the roller on it to the right. Now locate the notch on the piece you flipped back that has the blue plastic clips sticking into it. The silver shaft snaps in there. It does not feel right, but if it does not fall out when you close the adf door, you've got it. If there are other pieces loose, perhaps I can get you a few pictures from the one we have in the shop right now.
Apr 02, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
Printing problems
Hi, Is this happening on the flatbed or the ADF?
Dec 03, 2007 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 3390 Printer Logo
535 people viewed this question
Ben Johnson
