Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont turn when plugged back in and turned on.
    Sergeant:
    Champion:
  • 291 Answers
With belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Posted on Dec 10, 2008
Ge cycle electric dryer model number dde7200ralwh
take a neddle and put it in your reset button now you will lose your games but it worth it
Jan 02, 2014 | General Electric Dryers
Belt replaced around drum, too loose! Parts store insists it is the correct size for GE dryer. Model # DBXR453GT3WW (1996) Can't figure out what is wrong?
The part# i have for that model number for the belt is WE12M29 the previous part number for that was WE12M22 is either of those the part number for the belt ?? if yes it should be the correct one
one more thing that may help ya is view the diagram here of how it fits onto the idler pulley/motor pulley http://www.repairclinic.com/Dryer-Belt-Diagrams for your dryer it will be DIAGRAM L
GENE
Aug 29, 2011 | GE Dryers
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
How do i change belt
Take off the back of dryer. There should be a panel with about 6-8 screws in it. You will put your hand towards the middle of the drum on the outside and feel a groove. This is where the belt will ride. Just slide the belt over the drum and into the groove and then around the pulley on the motor. Your particular model may have a tensioner device on it that has a pulley on it as well. You would trace the belt on this pulley as well. Put the belt against the pressure side of the pulley. This would give it tension on the belt at all times. Let me know how you do with this.
Feb 08, 2009 | Whirlpool LER4634J Electric Dryer
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Jan 21, 2009 | LG DLE2512W Electric Dryer
We are trying to install a dryer belt onto a GE older moder dryer and can't figure it out. The model no is GDX8060RT429
Hi. thanks for the question. remove the top. lift , remove front. slide belt on drum .clean all lint. reinstall front and top. pull away from wall. remove back panel. motor on right idler pulley on left bring the belt down to push idler down ,to give the belt tension .put belt around motor pulley . thanks the appliance doc
Oct 02, 2008 | Dryers
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
352 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
