Question about Aiwa XR-M191 Shelf System
CD tray spontaneously opens and
My CD tray started to open on it's own after I tried to play some CD's, none of which worked, though they have worked in the recent past. help..
  • 4234 Answers
SOURCE: cd tray opens/closes by itself, intermittant full volume at start
I have a few ideas, but the model number is required for me to provide details. Can you please update this with the model number? Thanks, Dan
Posted on Jun 16, 2009
0 characters
1 Points
The AIWA CX-ZR525 wont play cd's, it will only pick them up and leave them there with no music
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 14, 2014 | Audio Shelf Systems
None of the cd tray is not opening top ones and the recording one at the bottom
Put a pin into the pin sized hole in the front of the tray and you are golden.
Dec 06, 2012 | Philips Audio Shelf Systems
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Oct 16, 2009 | Sony CMT-EX1 CD Shelf System
CD tray does not open.
you need to change the motor belt charge of the tray
Jul 23, 2009 | Sony CMT-EP707 CD Shelf System
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
CD player fails to read CDs
Cd cleaning disc is not advisable to clean your laser lens.. all you have to do is manually cleaning method! open the unit go to laser lens and clean it with 100% cotton buds then rub it slightly clockwise, but careful this is sensitive parts.
Sep 26, 2007 | Sharp XL-MP130 CD Shelf System
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Aiwa XR-M191 Shelf System Logo
23 people viewed this question
Top Aiwa Audio Shelf Systems Experts
Are you an Aiwa Audio Shelf System Expert? Answer questions, earn points and help others
