Question about Lexmark T632 Laser Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and restart it error message is gone and I can continue with my printing. I have tried changing out the print head and still get the same error eventually is this normal?
  • Big Cee Dec 14, 2008
    I ordered the parts I needed won’t know if it fixed the problem until I get them in thank you for your help.
  • 300 Answers
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Posted on Dec 10, 2008
Lexmark x544 108.02 printhead error
1. Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return?
Yes: Continue to Step 2.No: Print a test page. If the page prints, the printer is working correctly.
If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.Did the error message return?
Yes: Contact Lexmark @ 1-800-(539-6275) No: Print a test page. If the page prints, the printer is functioning correctly.
Aug 16, 2011 | Lexmark X544n All-In-One Laser Printer
T632 printer error : 34 short paper. What does that mean? Don't see 34 as a valid error code.
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
Aug 02, 2011 | Lexmark T632 Laser Printer
How do i find out what my current page count is on the Lexmark t632
Print a menu page:
press menu right button until utility menu is displayed, then press select (lcd display print menu), press select again and the printer print the menu page, where you can see all the parameters.
May 19, 2011 | Lexmark T632 Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
934 service Printhead error
head may be damaged, try reinstalling software first before you try to send the head repaired locally. may have to buy a new head if its dot matrix.
Jun 24, 2009 | Lexmark T632 Laser Printer
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
the mirror motor cable connected to
J3 on the engine board. If incorrect,
J3-7 measures approximately
engine board. If correct, replace the
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
Lexmark T632 Laser Printer Logo
946 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
