Question about Philips DVDR3576H DVD Recorder
I just purchased a phillips dvdr3576h and hooked it up to a new vizio. I cant make this thing work.
  • 8,596 Answers
Try the below first, but you may require additional assistance after this:
First, test to make sure the Philips remote is working by trying to play a dvd. If the remote control is working, then either A) your TV is set to the wrong channel, or B) you have not selected the correct source on the Philips remote.
Look at how the cables run from the back of the Philips to the TV. In the back of your TV, the slot that the cables are plugged in to is usually labelled "AV1, "AV2, "Video 1", "Input 1" or something like that. Change the television to the appropriate input/source channel.
Press the Source button on the Philips remote and make sure it says E1 or whatever the appropriate source is.
Then try changing channels using the Philips remote.
This does not exhaust every possibility, but you must check the above first to see if anything else might be wrong. If the above does not work, then I would double-check to make sure the cable/satellite box is connected to the Philips correctly.
-Tha Mp3 Doctor
Posted on Dec 25, 2008
What is remote control code for 42 inch vizio tv with phillips universal remote
Your Philips remote is universal so you can use its "code search" feature to find a suitable code. The codes are stored in the remote. If a thorough search does not produce a code, you may have to try another universal remote because not ll codes are stored in all remotes.
Oct 07, 2014 | Philips Phillips SRP1103/27 3-Device...
Cant hook up externl speaker to 32 inch vizio t.v.
those connections are designed to hook up to a reciever for surround, and are not amplified
Mar 05, 2013 | Vizio VO32LF 32 inch TV
Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Dec 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
I can't get my Playstation 2 or Wii to work with Vizio tv
I bought a RF Switcher Phillips SWS2325W/17 ...with this I was able to hook up my Wii...TV...DVD...and Directv...works fine...hope this helps
Dec 23, 2009 | Vizio Televison & Video
Download a manual
Here is the manual for the Philips DVDR3575H - if you have a DVDR3576H, the manual is exactly the same, as the only difference between the two models is the color of the outside casing:
http://www.p4c.philips.com/files/d/dvdr3575h_37/dvdr3575h_37_dfu_aen.pdf
-Tha Mp3 Doctor
Mar 22, 2009 | Philips Televison & Video
Cant get closed caption on my 32" vizio
You have to tune to a station that broadcasts closed caption.
If it does not work, you should go to the store you purchase the tv from and YOU try the same thing on the same display model you purchased. If it works there, maybe you should consider returning the set if under warranty. If it does not work you can get a sales agent to do it. You may be overlooking something.
Feb 15, 2009 | Vizio L32 32 in. LCD HDTV
Vizio vw42lf hdmi problem
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Aug 13, 2008 | Televison & Video
Philips DVDR3576H  DVD Recorder Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
