Problem with wt540
Hi All
Problem with wt540 1400spin.Wash enhance light and rinse hold and mini load option indicator lights are flashing on control panel.According to manual this states that machine has failed to drain because pump filter has blocked. Filter has been cleaned out along with pump and hose.Still not working.Lights still flashing. Tried pluging out for a few minutes. No go.Can anyone help. Already to go with my toolbox!!!
  • Washing Mach... Master
  • 3,463 Answers
Have you actually tried to pump water out, if you select a drain only position or drain and spin ,and hold the drain hose into a bucket or into the sink, you should see water pump out.
If it does not ,then you have a blockage somewhere, or your pump is faulty, assuming of course that the pump is getting power.
Plz leave feedback.
Posted on Dec 10, 2008
My washing machine is not working
Sounds like a communication error. remove lid and unplug top consol panel for 5 mins ,make sure connections on bottom pcb are tight ,if that dont work replace your PCB
Mar 08, 2015 | Hotpoint Aquarius WT540 Front
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Feb 09, 2011 | Washing Machines
Flashing lights
Sounds like a fault code Ring your local dealer They should have a list of codes and what they mean Hopefully they'll be kind enough to tell you over phone
Oct 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Dec 29, 2008 | Hotpoint Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
656 people viewed this question
Top Washing Machines Experts
